Home » Modeling » GMF (Graphical Modeling Framework) » figure label text enum values
figure label text enum values [message #52591] Thu, 21 September 2006 03:07 Go to next message
I have a emf element those name attribute may have only a value of a
predefined set of values (choice of enum). So its useful for users to
present a dropdown instead of a text field as value editor in the
diagram. How do I create such a DirectEditManager and where do I need to
instantiate and assign this? Does such a DropDownDirectEditManager
already exists? If no, what do I need to consider ?
Sven
Re: figure label text enum values [message #52681 is a reply to message #52591] Thu, 21 September 2006 05:11 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
I've submitted https://bugs.eclipse.org/bugs/show_bug.cgi?id=158116
sven krause wrote:
> Sven
Re: figure label text enum values [message #52734 is a reply to message #52681] Thu, 21 September 2006 05:43 Go to previous message
Hi Dmitry,
it's not for EEnum datatypes only. Sometime I need to limit the values
of the editor context driven. So I need to apply an "handmade" editor.
I just found a solution:
change in the XXXEditPart:
* @generated NOT
protected DirectEditManager getManager() {
if( manager == null ) {
View view = (View) getModel();
EObject modelElement = (EObject) view.getElement();
if(your decision) {
setManager(new DropDownDirectEditManager(this));
} else {
... old code ...
return manager;
and then create a class DropDownDirectEditManager extends
DirectEditManager adapting the methods from TextDirectEditManager:
1. adapting the constructor
1.2. adapting getCellEditorClass
1.3 adpating getCellEditorLocator and the used private class
2. overrride createCellEditorOn( Composite composite ) to use a
ComboBoxCellEditor and make sure that your CellEditor.getValue() returns
a String (just overriding doGetValue at ComboBoxCellEditor)
3. overrriding initCellEditor to initialize the drop down values
Sven
> sven krause wrote:
>> to instantiate and assign this? Does such a DropDownDirectEditManager
>> Thanks,
>> Sven
Previous Topic:Two different containers for one type of nodes
Next Topic:Missing methods in a generated Class
Current Time: Tue Jul 22 15:29:48 EDT 2025
Powered by FUDForum. Page generated in 0.03723 seconds
