Re: Is it possible to fill chart cells with fill patterns? [message #520530 is a reply to message #520519] |
Fri, 12 March 2010 18:10 |
Barry,
This would make a great enhancement request. Can you log it?
As a work around you have a couple of options:
1 - use a gradient and define it differently for each series.
2 - use an image. Using this approach you can build your own pattern
Just make a small gif with a color and a pattern, and the image will be
repeated in the bar.
Jason
BarryF wrote:
> Using color alone to distinguish bar (and other) chart cells is
> problematic for viewers with reduced color vision or those seeing charts
> printed in black and white. Typically s background patterns (such as
> cross hatch, stripes, etc) are used to also make the cells more
> distinguished. I see no way to do this in BIRT but it seems such a
> popular thing to do I hope I am just missing it.
> It seems easy to select colors for Bar and other chart type cells. There
> is a palette, etc. to do this. Background images are allowed but that
> seems an overly complex way to create background patterns for cells.
FUDForum. Page generated in 0.03761 seconds
