Re: Hiding empty rows in a cross tab [message #518652 is a reply to message #518550] |
Thu, 04 March 2010 16:58 |
Damian,
There is a property for hiding empty rows. Select the crosstab, then
the property editor, then Empty Rows/Columns.
Jason
Damian Sirbu wrote:
> Greetings everyone.
> I am looking for a solution to hide empty rows in a crosstab, using java
> event handlers. (the 'row' may contain elements from several groups and
> a summary field)
> My problem is that I did not found any suitable event handler to extend,
> or a 'crosstab' javscript object in the documentation.
> Any hint or advice would be appreciated.
> Thank you
Re: Hiding empty rows in a cross tab [message #518656 is a reply to message #518652] |
Thu, 04 March 2010 12:16 |
For script take a look at this blog post.
http://birtworld.blogspot.com/2010/02/birt-crosstab-scriptin g.html
Jason
Jason Weathersby wrote:
> Damian,
> Jason
> Damian Sirbu wrote:
>> Greetings everyone.
>> java event handlers. (the 'row' may contain elements from several
>> groups and a summary field)
>> extend, or a 'crosstab' javscript object in the documentation.
>> Thank you
FUDForum. Page generated in 0.02848 seconds
