Home » Language IDEs » Java Development Tools (JDT) » Re: What happened to the Projects Tab ?
Re: What happened to the Projects Tab ? [message #516992] Thu, 25 February 2010 07:08
On 2/19/10 4:59 PM, sasha wrote:
> I haven't used Eclipse since 3.1, and downloaded galileo Java EE bundle.
> however a lot of things seem to have changed.
> I am looking for Java Build Path, under Project->Properties and only see
> Resource
> Builders
> Project References
> Run/Debug Settings
> Server...
> and so on.
> I am looking for what it used to be
> Info
> Builders
> Java Build Path
> Java code Style
> Java compiler
> Project References
Note: this topic is probably better placed in the Java Development Tools
(JDT) group; I'm copying it there.
The most likely reason you don't see a Java Build Path option is that
the project you're looking at is not actually a Java project. When you
created it, what did you select?
Hope this helps,
Eric
Previous Topic:what does resources mean in refactoring
Next Topic:user libraries in eclipse 3.5.1
Current Time: Mon Mar 17 01:49:32 EDT 2025
Powered by FUDForum. Page generated in 0.02950 seconds
