Re: Tooltip on the line [message #516648 is a reply to message #516515] |
Wed, 24 February 2010 16:21 |
Enrico,
This currently not supported. You can log an enhancement request if you
want to.
Jason
Enrico Schnepel wrote:
> Hello,
> I would like to display a tooltip on a lineseries without a marker. how is
> this possible? I have only success displaying tooltips on a datapoint when
> there is a marker. An ICON_MARKER with an transparent imagae did work. but
> this is not the way I would like to go.
> even better would be a way to display tooltips on the line also for values
> between two data points.
> Any Ideas?
> Thanks
> Enrico
Re: Tooltip on the line [message #516659 is a reply to message #516649] |
Wed, 24 February 2010 12:06 |
I think this is two request. Can you log two?
> Hello Jason,
> is both unsupported (tooltip for empty marker as well as tooltip for line)
> as this might be two requests...?
> Enrico
> "Jason Weathersby" <jasonweathersby@windstream.net> schrieb im Newsbeitrag
> news:hm3jf2$g7c$2@build.eclipse.org...
>> Enrico,
>> want to.
>> Jason
>>> Hello,
>>> is this possible? I have only success displaying tooltips on a datapoint
>>> when there is a marker. An ICON_MARKER with an transparent imagae did
>>> work. but this is not the way I would like to go.
>>> values between two data points.
>>> Any Ideas?
>>> Thanks
>>> Enrico
Re: Tooltip on the line [message #516964 is a reply to message #516776] |
Thu, 25 February 2010 10:50 |
> Hello Jason,
> done so.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=303857
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=303858
> Enrico
> news:hm3lcq$lrn$2@build.eclipse.org...
>>> Hello Jason,
>>> line) as this might be two requests...?
>>> Enrico
>>> Newsbeitrag news:hm3jf2$g7c$2@build.eclipse.org...
>>>> Enrico,
>>>> want to.
>>>> Jason
>>>>> Hello,
>>>>> datapoint when there is a marker. An ICON_MARKER with an transparent
>>>>> imagae did work. but this is not the way I would like to go.
>>>>> Any Ideas?
>>>>> Thanks
>>>>> Enrico
FUDForum. Page generated in 0.03233 seconds
