Mantis 1.1 integration [message #52128] |
Mon, 07 July 2008 13:27  |
Originally posted by: fkereki.gmail.com
I just installed Mylyn (including the Mantis connector) for Eclipse
Europa, and I got the following problem: when I try to connect to a Mantis
server, the "Server" field offers both Mantis 1.0a5 and 1.1.0, but in
"Additional Settings", only 1.0a5 if offered.
I cannot connect to Mantis.
What am I doing wrong?
Re: Mantis 1.1 integration [message #52375 is a reply to message #52128] |
Tue, 08 July 2008 11:15  |
> Mantis server, the "Server" field offers both Mantis 1.0a5 and 1.1.0,
> but in "Additional Settings", only 1.0a5 if offered.
Best to ask on the Mylyn-Mantis forums at source forge. With that said,
I'm one of the maintainers of the connector.
It shouldn't matter which version of the connector you choose in the
Advanced settings, however it does matter in the Template. If you are
trying to connect to a Mantis Bug Tracker that is using 1.1.x or
greater, you need to tuse the template 1.1.0 template as it will setup
the url correctly.
You will also need your user name and password, annoymous access isn't
allowed.
Re: Mantis 1.1 integration [message #591024 is a reply to message #52128] |
the url correctly.
allowed.
FUDForum. Page generated in 0.04441 seconds
