Home » Language IDEs » Java Development Tools (JDT) » Java Build Path
Java Build Path [message #515722] Fri, 19 February 2010 17:08 Go to next message
I haven't used Eclipse since 3.1, and downloaded galileo Java EE bundle.
however a lot of things seem to have changed.
I am looking for Java Build Path, under Project->Properties and only see
Resource
Builders
Project References
Run/Debug Settings
Server...
and so on.
I am looking for what it used to be
Info
Builders
Java Build Path
Java code Style
Java compiler
Project References
Is the Projects Properties tab different for plain java version of eclipse
versus JEE ?
Re: Java Build Path [message #515739 is a reply to message #515722] Fri, 19 February 2010 22:45 Go to previous messageGo to next message
> Resource
> Builders
> Project References
> Run/Debug Settings
> Server...
> and so on.
> Info
> Builders
> Java Build Path
> Java code Style
> Java compiler
> Project References
> versus JEE ?
If the Build Path entry isn't available, then my guess is you don't have
a Java project (Doesn't have the Java Nature).
Re: Java Build Path [message #515774 is a reply to message #515722] Sat, 20 February 2010 12:18 Go to previous messageGo to next message
As the other responder indicated, your project appears to not have the Java "nature". How did you create the project?
You could recreate the project as a "Java Project" (type "java project" into the "Select a wizard" dialog (press Ctrl-n to bring this up, or select File->New->Other from the main menu)).
If recreating the project is awkward, you might be able to directly edit the ".project" file for your project.
For instance, this is the ".project" file for a plain Java project in my workspace:
<projectDescription>
	<name>timings</name>
	<comment></comment>
	<projects>
	</projects>
	<buildSpec>
		<buildCommand>
			<name>org.eclipse.wst.common.project.facet.core.builder</name>
			<arguments>
			</arguments>
		</buildCommand>
		<buildCommand>
			<name>org.eclipse.jdt.core.javabuilder</name>
			<arguments>
			</arguments>
		</buildCommand>
	</buildSpec>
	<natures>
		<nature>org.eclipse.jdt.core.javanature</nature>
		<nature>org.eclipse.wst.common.project.facet.core.nature</nature>
	</natures>
</projectDescription>
If you're unsure, make a copy of your .project file before doing this, but if you add the "org.eclipse.jdt.core.javanature" nature to the "natures" list, and the "org.eclipse.jdt.core.javabuilder" build command, it will probably make it a Java project just as if you had created it as one.
Re: Java Build Path [message #516114 is a reply to message #515774] Mon, 22 February 2010 14:01 Go to previous message
Thanks! Yes, that was the problem- I had checked out a directory with a
..project file which did not have a java nature...
Now I am stuck with proxy setting problems...
"David M. Karr" <davidmichaelkarr@gmail.com> wrote in message
news:hlp5i6$1fr$1@build.eclipse.org...
> workspace:
> <comment></comment>
> <projects>
> </projects>
> <buildSpec>
> <buildCommand>
> <name>org.eclipse.wst.common.project.facet.core.builder</name >
> <arguments>
> </arguments>
> </buildCommand>
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> </buildSpec>
> <natures>
> <nature>org.eclipse.wst.common.project.facet.core.nature</nature >
> </natures>
Previous Topic:Compiles too many files when add one method
Next Topic:Parameters code style options
Current Time: Sun Mar 16 07:50:47 EDT 2025
Powered by FUDForum. Page generated in 0.03838 seconds
