Home » Eclipse Projects » Buckminster dev » RE: [buckminster-dev] CSPEC Location
RE: [buckminster-dev] CSPEC Location [message #4615] Mon, 18 February 2008 11:04
Originally posted by: BroderickE.gsicommerce.com
Hi Thomas,
Thanks for the reply. The project I'm trying to "buckminsterize" is not
an eclipse plugin or a feature, so I guess I'll have to use the
buckminster.cpec for my meta-data.
I was wondering if I could describe to you what I would like to
accomplish with buckminster and get your opinion on how feasible it is
(and maybe get some advice on how to move forward)...
Basically, we have a large java project in cvs which is pretty difficult
to set up in eclipse, especially for new hires. No .classpath files,
..project files, or jar dependencies are checked in with the source. When
a developer wants to work on the project in eclipse, it obviously takes
a while to find all these dependencies in order to configure the build
path correctly.
So really, all I would like to do with Buckminster right now would be to
checkout the project, set up the source directories, and set up the
build path in one step. I'm starting to think that Buckminster is really
more of a tool for eclipse features/plugins, so would it be able to help
me out with my situation?
Evan
-----Original Message-----
[mailto:buckminster-dev-bounces@eclipse.org] On Behalf Of Thomas
Hallgren
Sent: Monday, February 11, 2008 5:27 PM
To: Buckminster developer discussions
Subject: Re: [buckminster-dev] CSPEC Location
Hi Evan,
The 'componentTypes' attribute tells Buckminster what the provider
should expect in the components that it finds. In your case, you have
specificed three possible types:
"osgi.bundle,eclipse.feature,buckminster"
The 'osgi.bundle' component type assumes that meta-data can be found in
files like META-INF/MANIFEST.MF, plugin.xml, or fragment.xml. The
eclipse.feature will look for the 'eclipse.xml' file. The 'buckminster'
type looks for the 'buckminster.cspec.
If none of these files are present in the component, a provider with
your setting for the 'componentTypes' attribute will fail.
If you don't have any meta-data at all and if you are happy using the
project name as the component name, then you can use
componentTypes="unknown"
How are your components structured? Do they have any meta-data that
describes things like name, version, and dependencies? If it does, and
if Buckminster has no component type that recognizes it, such a type is
fairly easy to add.
Thomas Hallgren
brodericke wrote:
> Hi All,
> I just started playing around with buckminster today and I was
wondering if
> someone could answer a couple questions for me.
> I've been trying to create a cquery and rmap for a project which lives
in
> our cvs repository. Here's my provider configuration:
> <provider
> readerType="cvs"
> componentTypes="osgi.bundle,eclipse.feature,buckminster"
> source="true" mutable="false">
> <uri
format=":pserver:brodericke:*****@********:/opt/cvsroot,{0} ">
> <bc:propertyRef key="buckminster.component" />
> </uri>
> </provider>
> It seems to me like I'm only able to materialize my cquery when there
is a
> cspec file in the root of my project in cvs. When I take out the cspec
file,
> I see errors like:
> ERROR [0001] : No suitable provider for component
> buckminster_project:buckminster was found in searchPath default
> ERROR [0001] : Provider
cvs(:pserver:brodericke:*****@********:/opt/cvsroot,buckmins ter_project)
: No
> match found for component buckminster_project
> Is this observation correct or am I just missing something? Do I need
to
> have a cspec file checked in under the root of my project in cvs? If
that's
> true, is there any way to point buckminster to a cspec file that's
located
> somewhere else?
> Evan
_______________________________________________
buckminster-dev mailing list
buckminster-dev@eclipse.org
https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Previous Topic:Re: [buckminster-dev] help with CVS
Next Topic:Re: [buckminster-dev] CSPEC Location
Current Time: Sat Jul 19 14:10:06 EDT 2025
Powered by FUDForum. Page generated in 0.37270 seconds
