Re: Pie chart SWT problems [message #515150 is a reply to message #514968] |
Wed, 17 February 2010 21:48 |
Boris,
Can you open a bug for problem 2? I do not see what you are referring
to in problem 1.
Jason
Boris Stepanov wrote:
> Forget about picture.
> BIRT version: 2.5.1.
>> Hi everybody,
>> I have RCP application and use BIRT Chart API plug-ins for generating
>> charts. They have tooltips and interactive abilities.
>> I have discovered the following problems:
>> 1. Borders of the slices are defined incorrectly (see attached
>> picture). I have not reproduced it in SVG + imagemap.
>> 2. Each tooltip uses one GDI descriptor of the operation system and
>> does not free it. I have monitored it in Windows Task Manager. When I
>> move mouse over chart for 5 minutes, my application hangs.
>> The second problem is actual for all charts in SWT mode. The first one
>> only for Pie Charts.
>> I think that both bugs are critical.
>> Any suggestions?
>> Thanks in advance.
Re: Pie chart SWT problems [message #515188 is a reply to message #515150] |
Wed, 17 February 2010 23:12 |
Boris Stepanov Messages: 68 Registered: July 2009 |
Member |
Hi Jason,
Thanks for the answer.
I will open a bug for problem 2 and will publish its number there.
I will try to describe first problem in details.
Pie chart consist from slices, each slice has value that defines size of
the slice. When we move mouse over each slice, tooltip has to be shown
and by default it shows value of the slice under it, but when I have
many slices I see wrong tooltips (sometimes I can reproduce it with less
number of slices), I see tooltip from other slice. For example on the
picture I keep mouse over slice with value 19456, but see value 10506
(this slice is located above), so I think that there is a bug in the
algorithm defining slice using mouse location and it is reproduced only
for SWT renderer, I have verified it in PNG with image map and all
tooltips are shown correctly.
> Boris,
> to in problem 1.
> Jason
>>> Hi everybody,
>>> one only for Pie Charts.
>>> Any suggestions?
>>> Thanks in advance.
Re: Pie chart SWT problems [message #515320 is a reply to message #515188] |
Thu, 18 February 2010 13:32 |
I see now. Please open a separate bug for this. Thanks
Jason
> Hi Jason,
>> Boris,
>> to in problem 1.
>> Jason
>>>> Hi everybody,
>>>> generating charts. They have tooltips and interactive abilities.
>>>> I move mouse over chart for 5 minutes, my application hangs.
>>>> Any suggestions?
>>>> Thanks in advance.
Re: Pie chart SWT problems [message #516486 is a reply to message #515320] |
Wed, 24 February 2010 08:07 |
Member |
Hi Jason,
I've opened bug for the second problem
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=303720).
And I've found bug for the first problem
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=285851), but as I
understand it wasn't fixed correctly, because it can be reproduced now.
Shall I reopen this issue?
> Jason
>> Hi Jason,
>> of the slice. When we move mouse over each slice, tooltip has to be
>> shown and by default it shows value of the slice under it, but when I
>> have many slices I see wrong tooltips (sometimes I can reproduce it
>> with less number of slices), I see tooltip from other slice. For
>> example on the picture I keep mouse over slice with value 19456, but
>> see value 10506 (this slice is located above), so I think that there
>> is a bug in the algorithm defining slice using mouse location and it
>> is reproduced only for SWT renderer, I have verified it in PNG with
>> image map and all tooltips are shown correctly.
>>> Boris,
>>> referring to in problem 1.
>>> Jason
>>>>> Hi everybody,
>>>>> Any suggestions?
>>>>> Thanks in advance.
Re: Pie chart SWT problems [message #516624 is a reply to message #516486] |
Wed, 24 February 2010 15:42 |
You can re-open, but it sounds like a limitation with SWT.
Jason
> Hi Jason,
>> Jason
>>> Hi Jason,
>>>> Boris,
>>>> Jason
>>>>>> Hi everybody,
>>>>>> and does not free it. I have monitored it in Windows Task Manager.
>>>>>> When I move mouse over chart for 5 minutes, my application hangs.
>>>>>> Any suggestions?
>>>>>> Thanks in advance.
FUDForum. Page generated in 0.03440 seconds
