JDialog Creation [message #52005] |
Mon, 26 July 2004 03:37  |
Originally posted by: masterelettronik.yahoo.it
How ican make a JDialog with VE ? Can I make it changing the class
derived from JFrame to JDialog?
Thank you for the help!
(Excuse my poor English...)
Re: When is M2 sceduled? [message #52082 is a reply to message #52056] |
Mon, 26 July 2004 16:39  |
Winni,
Any day now, just resolving a last few bugs before pushing it out the door.
- Jeff
Winni P. wrote:
> Hi Jeff,
> when is the release of M2 Sceduled?
> Thanks
> Winni
Re: JDialog Creation [message #595861 is a reply to message #52005] |
Mon, 26 July 2004 09:08  |
In the New Visual Class Wizard, select Other as the visual class you'd
like to extend, then press the Browse... button next to the Superclass
field. Enter JDialog, then press Finish.
This should work ok. We've had a few problems recently with extending
JDialog. If the resulting code has problems, if you fix the code
yourself it should work. Otherwise, please try out the forthcoming M2
build.
- Jeff
Re: When is M2 sceduled? [message #595867 is a reply to message #52030] |
Mon, 26 July 2004 15:34  |
Hi Jeff,
Winni
> build.
> - Jeff
Re: When is M2 sceduled? [message #595874 is a reply to message #52056] |
Winni,
- Jeff
Winni P. wrote:
> Hi Jeff,
> Thanks
> Winni
FUDForum. Page generated in 0.03763 seconds
