Cannot view non-test reports with BIRT Viewer 2.5.1 [message #514210] |
Fri, 12 February 2010 20:35 |
Christoph Messages: 55 Registered: July 2009 |
Member |
I'm having difficulty viewing reports with BIRT Report Viewer:
Viewer Version : 2.5.1
Engine Version: 2.5.1
JRE version: 1.6.0_12
Tomcat version: 6.0
In addition to the two test reports that are installed with the report viewer, I have deployed a simple, text only, report called test_report.rptdesign, and SalesInvoice.rptdesign ( http://www.eclipse.org/birt/phoenix/examples/solution/SalesI nvoice.rptdesign). I previewed all of these reports with BIRT Report Designer 2.5.1.
I can successfully view the two test reports using the following URLs:
http://myhost:8080/birt-viewer/frameset?__report=test.rptdes ign
http://myhost:8080/birt-viewer/frameset?__report=test1.rptde sign
However, when I attempt to access the other reports as follows:
http://myhost:8080/birt-viewer/frameset?__report=test_report .rptdesign
http://myhost:8080/birt-viewer/frameset?__report=SalesInvoic e.rptdesign
I get the following error:
org.eclipse.birt.report.exception.ViewerException: The report file : /opt/tomcat6/webapps/birt-viewer/test_report.rptdesign does not exist or contains errors. (Full stacktrace below under Error 1.)
I am stumped as to why some reports work and the others don't. Any help with this would be most welcome.
Also, when I put any of these reports into the birt-viewer/report directory and try to access them (e.g.: http://myhost:8080/birt-viewer/frameset?__report=/report/tes t.rptdesign), I get the following error:
org.eclipse.birt.report.exception.ViewerException: There is no report design object available. (Full stacktrace below under Error 2.)
However, this issue will be moot when the first one is resolved.
Thanks in advance,
Christoph
Error 1:
at org.eclipse.birt.report.context.ViewerAttributeBean.getDesig nHandle(ViewerAttributeBean.java:659)
at org.eclipse.birt.report.context.ViewerAttributeBean.__init(V iewerAttributeBean.java:231)
at org.eclipse.birt.report.context.BaseAttributeBean.init(BaseA ttributeBean.java:233)
at org.eclipse.birt.report.context.ViewerAttributeBean.<init>(ViewerAttributeBean.java:116)
at org.eclipse.birt.report.context.BirtContext.__init(BirtConte xt.java:44)
at org.eclipse.birt.report.context.BaseContext.<init>(BaseContext.java:69)
at org.eclipse.birt.report.context.BirtContext.<init>(BirtContext.java:30)
at org.eclipse.birt.report.servlet.ViewerServlet.__getContext(V iewerServlet.java:150)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(BirtSoapMessageDispatcherServlet.java:151)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF ilter.java:68)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:849)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:454)
at java.lang.Thread.run(Thread.java:619)
Error 2:
at org.eclipse.birt.report.context.ViewerAttributeBean.__init(V iewerAttributeBean.java:233)
Re: Cannot view non-test reports with BIRT Viewer 2.5.1 [message #514539 is a reply to message #514210] |
Mon, 15 February 2010 12:38 |
Christoph,
On the first error where are you putting the design?
Also open the SalesInvoice.rptdesign in the designer to verify that the
download is not corrupt.
Jason
Christoph wrote:
> Hello,
> Tomcat version: 6.0
> Thanks in advance,
> Christoph
> Error 1:
> contains errors.
> at
> xt.java:44)
> at
> at
> ilter.java:68)
> stValve.java:128)
> rtValve.java:102)
> apter.java:293)
> ssor.java:849)
> t.java:454)
> Error 2:
> at
> xt.java:44)
> at
> at
> ilter.java:68)
> stValve.java:128)
> rtValve.java:102)
> apter.java:293)
> ssor.java:849)
> t.java:454)
Re: Cannot view non-test reports with BIRT Viewer 2.5.1 [message #514587 is a reply to message #514562] |
Mon, 15 February 2010 16:20 |
Christoph,
It should have found it under the report directory. Try
without the leading slash:
eg
__report=report/test.rptdesign
You can also set the working folder in the web.xml
<context-param>
<param-name>BIRT_VIEWER_WORKING_FOLDER</param-name>
<param-value></param-value>
</context-param>
Jason
Christoph wrote:
> Hi Jason,
> As it turns out, I had two birt-viewer installations on the host and I
> was placing reports in the wrong one. Everything works fine now. My
> apologies for the oversight.
> The reports are all in the "root" birt-viewer directory, and I still get
> Error 2 when I place them in the birt-viewer/report/ subdirectory. But
> everything is fine when they are in the root directory, so this isn't an
> issue anymore.
> Feeling sheepish,
> Christoph
FUDForum. Page generated in 0.03297 seconds
