Home » Language IDEs » Java Development Tools (JDT) » What I type isn't what shows up(Somehow I think I've toggled on a different locale for Eclipse)
What I type isn't what shows up [message #514006] Thu, 11 February 2010 22:19 Go to next message
I was working away when Eclipse (Ganymede) sort of stopped responding.... and I was whacking away at the keys before I knew it. When it did start responding, what I type isn't what shows up.
For example, if I type a less than symbol (<), I get a semi-colon (;). If I type a semi-colon, I get a spanish n (the one with the little squiggly above it). I type a left paren, I get a right one, a question mark (?) becomes an underscore (_).
I suspect my editor is "thinking" in another locale, or maybe it thinks it is a different device but I don't know how to change it back.
I looked through preferences and nothing jumped out at me. Is there like an alternate keyboard or keyboard shortcut that toggles to different languages?
Re: What I type isn't what shows up [message #514028 is a reply to message #514006] Fri, 12 February 2010 03:56 Go to previous messageGo to next message
The used input language is an OS setting.
Dani
Re: What I type isn't what shows up [message #514130 is a reply to message #514028] Fri, 12 February 2010 09:25 Go to previous message
After restarting the computer overnight, it seems to be back to normal. I had, however, narrowed it down to symbols... normal characters typed just fine, but it was like the symbol table had shifted off by some.
In any case, I was going to map the whole thing this morning and see if there was some science to how far they were off, but, like I said, it's back to normal.
I'm not sure if it required a full machine restart (though Eclipse was the only thing doing it), or just to have restarted Eclipse.
Either way, kind of strange.
Previous Topic:How to create a build.xml file and use it as an ANT scipt for compiling?
Next Topic:No Database Found ?????
Current Time: Wed Mar 19 21:36:14 EDT 2025
Powered by FUDForum. Page generated in 0.05134 seconds
