Home » Language IDEs » Java Development Tools (JDT) » Chart Axis Fix-age
Chart Axis Fix-age [message #513752] Thu, 11 February 2010 01:19
package org.swtchart.examples;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Shell;
import org.swtchart.Chart;
import org.swtchart.ILineSeries;
import org.swtchart.ISeries.SeriesType;
 * An example for line chart.
public class LineChartExample {
	private static final double[] ySeries = { 0.0, 0.38, 0.71, 0.92, 1.0, 0.92,
			0.71, 0.38, 0.0, -0.38, -0.71, -0.92, -1.0, -0.92, -0.71, -0.38 };
	 * The main method.
	 * @param args
	 *            the arguments.
		Display display = new Display();
		Shell shell = new Shell(display);
		shell.setText("Line Chart Example");
		shell.setSize(500, 400);
		shell.setLayout(new FillLayout());
		// create a chart
		Chart chart = new Chart(shell, SWT.NONE);
		// set titles
		chart.getTitle().setText("Line Chart Example");
		chart.getAxisSet().getXAxis(0).getTitle().setText("Data Points");
		chart.getAxisSet().getYAxis(0).getTitle().setText("Amplitude");
		// create line series
		ILineSeries lineSeries = (ILineSeries) chart.getSeriesSet()
				.createSeries(SeriesType.LINE, "line series");
		lineSeries.setYSeries(ySeries);
		// adjust the axis range
		chart.getAxisSet().adjustRange();
		shell.open();
		while (!shell.isDisposed()) {
			if (!display.readAndDispatch()) {
				display.sleep();
		display.dispose();
Hi, I'm attempting to use the above sample to ask the question as I'm not suppose to reveal my client's source codes.
I'm trying to do out a graph as shown in the sample, however, the above graph have their range of X and Y axis based on the maximum values.
For example,
This is the original output. Notice the X axis have 15 data points
http://cid-ff31e0d0d4c5b9a9.skydrive.live.com/self.aspx/Imag es/1.png
This is what happened when I remove all the values except the first 3.
The X axis now have 2 data point instead.
http://cid-ff31e0d0d4c5b9a9.skydrive.live.com/self.aspx/Imag es/2.PNG
Is there a way for me to make the axis fixed, so I can make the X axis in the 2nd sample have 15 data points?
Previous Topic:Bind Ant task to keystroke
Next Topic:Multi-line Formatting
Current Time: Sun Mar 16 06:39:53 EDT 2025
Powered by FUDForum. Page generated in 0.02590 seconds
