Problem with Eclipse and /usr/lib/eclipse/startup.jar on Ubuntu [message #512351] |
Thu, 04 February 2010 08:16 |
Originally posted by: nick.cortexcontrollers.com
I apologise that is is a copy of an earlier post to eclipse.platform. This
forum seems more appropriate....
I had Eclipse working satisfactorily on an Ubuntu 8.04 machine after using
"apt-get install eclipse sun-java6-jdk".
I then tried to add extra features but rather foolishly attempted to load
every option. This got very confused so I thought I would start again and
looked up how to remove eclipse. I read that the way to do this was to
remove /usr/lib/eclipse and /usr/local/lib/eclipse. I did this. I realise
now that I should probably have used "apt-get remove eclipse"!
Anyway, I have re-installed eclipse using "apt-get install eclipse" but now
every time I try to run eclipse I get the message "Unable to access jarfile
/usr/lib/eclipse/startup.jar" and Eclipse fails to run. When I look in
"/usr/lib/eclipse" I see that indeed it contains no file called
"startup.jar".
I have looked on the web and see that others have had similar problems but
could not see a solution.
I have tried "apt-get remove eclipse" and "apt-get install eclipse" many
times but have had no success. As I recall, the first time I installed
eclipse it was a fairly lengthy process generating lots of screen output---
it looked as lots of files were being generated. The recent "remove" and
"install" processes are very quick which seems to imply "remove" doesn't
actually remove everything. Is there some way I can force a completely new
"install from scratch"? Or is there some other solution?
Thank you,
Nick Toop
FUDForum. Page generated in 0.03714 seconds
