Home » Language IDEs » Java Development Tools (JDT) » Error - Help
Error - Help [message #511297] Mon, 01 February 2010 03:02 Go to next message
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTException: Widget is disposed)
at org.eclipse.swt.SWT.error(SWT.java:3884)
at org.eclipse.swt.SWT.error(SWT.java:3799)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:388)
at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:507)
at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.r un(ProgressMonitorJobsDialog.java:275)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor. disconnectFromWorkspace(IDEWorkbenchAdvisor.java:460)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor. postShutdown(IDEWorkbenchAdvisor.java:316)
at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:27 32)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:9 39)
at org.eclipse.ui.internal.Workbench.access$15(Workbench.java:8 56)
at org.eclipse.ui.internal.Workbench$23.run(Workbench.java:1100 )
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1098)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1070)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:721)
at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:700)
at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindo w.java:816)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:814)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:741)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:68 7)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:92)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:308)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1645)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3948 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:342)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1578)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2010)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4589 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2405 )
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:492)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4036 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 10)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3471)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Caused by: org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:3770)
at org.eclipse.swt.widgets.Widget.error(Widget.java:463)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:336)
at org.eclipse.swt.widgets.Tree.setRedraw(Tree.java:4715)
at org.eclipse.jst.jee.ui.internal.navigator.JEE5ContentProvide r$1.run(JEE5ContentProvider.java:122)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
... 73 more
Can anyone please tell me why I am getting this error. Thanks for ur support brothers Confused .
Re: Error - Help [message #511517 is a reply to message #511297] Mon, 01 February 2010 15:46 Go to previous messageGo to next message
Insufficient info
http://catb.org/~esr/faqs/smart-questions.html
Re: Error - Help [message #511757 is a reply to message #511297] Tue, 02 February 2010 13:16 Go to previous message
thks man, i'll try to be more specific!!!
Previous Topic:How to create Marker on elements which are not IResource?
Next Topic:References to non-existing library
Current Time: Sat Mar 15 21:16:30 EDT 2025
Powered by FUDForum. Page generated in 0.05053 seconds
