Home » Archived » M2M (model-to-model transformation) » [ATL]: Installation from source
[ATL]: Installation from source [message #51627] Mon, 09 July 2007 11:50 Go to next message
Bas Graaf is currently offline Bas GraafFriend
Hi All,
I tried to install ATL and AM3 from source. I followed the instructions
on the Wiki. The problems described below occur when I export the
adt/am3 plugins and subsequently install them (i.e., not when running a
second workbench from eclipse).
When I open the ATL editor I get the first exception below and the
navigator does not show up. When opening the AM3 perpective I get the
second exception below and the resource navigotor does not show up.
Does anybody know a solution to this problem?
Kind regards,
Bas.
when I open the ATL editor I get:
java.lang.NoClassDefFoundError:
org/eclipse/m2m/atl/engine/injectors/Injector
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:498)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:468)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:427)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:410)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:334)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
org.eclipse.m2m.atl.adt.ui.outline.AtlContentOutlinePage.set Unit(AtlContentOutlinePage.java:438)
org.eclipse.m2m.atl.adt.ui.outline.AtlContentOutlinePage.cre ateControl(AtlContentOutlinePage.java:321)
org.eclipse.ui.views.contentoutline.ContentOutline.doCreateP age(ContentOutline.java:134)
at org.eclipse.ui.part.PageBookView.createPage(PageBookView.jav a:399)
at org.eclipse.ui.part.PageBookView.partActivated(PageBookView. java:743)
at org.eclipse.ui.internal.PartListenerList$1.run(PartListenerL ist.java:72)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
org.eclipse.ui.internal.PartListenerList.fireEvent(PartListe nerList.java:57)
org.eclipse.ui.internal.PartListenerList.firePartActivated(P artListenerList.java:70)
org.eclipse.ui.internal.PartService.firePartActivated(PartSe rvice.java:73)
at org.eclipse.ui.internal.PartService.setActivePart(PartServic e.java:171)
org.eclipse.ui.internal.WorkbenchPagePartList.fireActivePart Changed(WorkbenchPagePartList.java:56)
at org.eclipse.ui.internal.PartList.setActivePart(PartList.java :126)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:3207)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:588)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2604)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2528)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2520)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2505)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2500)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2485)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:388)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:350)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:98)
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.java:98)
org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAct ion(OpenActionGroup.java:125)
org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAct ion(MainActionGroup.java:328)
org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen( ResourceNavigator.java:679)
org.eclipse.ui.views.navigator.ResourceNavigator$6.open(Reso urceNavigator.java:434)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:817)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:815)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1069)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1168)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:249)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:243)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:283)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3166)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2842)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
when opening the AM3 perspective I get:
org/eclipse/m2m/atl/engine/vm/nativelib/ASMOclAny
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 89)
at java.lang.Class.getConstructor0(Class.java:2699)
at java.lang.Class.newInstance0(Class.java:326)
at java.lang.Class.newInstance(Class.java:308)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:157)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:234)
org.eclipse.ui.internal.registry.ViewDescriptor.createView(V iewDescriptor.java:69)
org.eclipse.ui.internal.ViewReference.createPartHelper(ViewR eference.java:292)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReferen ce.java:197)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 0)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:52 5)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:140)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:394)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1144)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1097)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:13 11)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:601)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:532)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:562)
org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper.java:244)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:815)
org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:3284)
org.eclipse.ui.internal.WorkbenchPage.busyResetPerspective(W orkbenchPage.java:893)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:829)
at org.eclipse.ui.internal.WorkbenchPage$11.run(WorkbenchPage.j ava:2766)
org.eclipse.ui.internal.WorkbenchPage.resetPerspective(Workb enchPage.java:2764)
org.eclipse.ui.internal.ResetPerspectiveAction.run(ResetPers pectiveAction.java:58)
at org.eclipse.ui.internal.PerspectiveAction.run(PerspectiveAct ion.java:70)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
Re: [ATL]: Installation from source [message #51884 is a reply to message #51627] Tue, 10 July 2007 15:10 Go to previous messageGo to next message
Frédéric Jouault is currently offline Frédéric JouaultFriend
Hi Bas,
It seems that classes from the org.eclipse.m2m.atl.engine.vm plugin are
not found. Can you please make sure that this plugin is installed?
Frédéric Jouault
Bas Graaf wrote:
> Hi All,
> Kind regards,
> Bas.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [ATL]: Installation from source [message #52201 is a reply to message #51884] Thu, 12 July 2007 11:38 Go to previous message
Hi Frederic,
That plugin is in fact installed. I tried the following with a new
installation of Eclipse (3.2.1) and EMF (2.2.3):
- Import required ATL and AM3 plugin projects from CVS
- Add antlr.jar and mdr-jars
- Compile
- Start (secondary) Eclipse instance
--> AM3 and ATL work as they should
- Export set of imported projects as plugins
- Extract in plugin directory
- Restart Eclipse (-clean)
--> switching to AM3 perspective, and opening ATL editor gives the
exceptions below
Kind regards,
Bas.
Frédéric Jouault wrote:
> Hi Bas,
> Frédéric Jouault
> Bas Graaf wrote:
>> Hi All,
>> instructions on the Wiki. The problems described below occur when I
>> export the adt/am3 plugins and subsequently install them (i.e., not
>> when running a second workbench from eclipse).
>> Thanks,
>> Kind regards,
>> Bas.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:[ATL] Executing ATL transformations by using ANT scripts: profiled models
Next Topic:[ATL]Problem with toSequence operator
Current Time: Thu Jan 21 16:02:04 GMT 2021
Powered by FUDForum. Page generated in 0.02216 seconds
