BIRT 2.5.1: TOC of Headings in PDF [message #510167] |
Tue, 26 January 2010 15:39 |
Hi there
It appears to me that the TOC feature of BIRT is not usable for the following needs; maybe (hopefully) I'm wrong:
We need a TOC feature similar as in the common text processors (e.g. MS Word):
- Mark some sections/headings as relevant for the TOC
- place a section at the beginning of the document that lists those headings including the appropriate page numbers
- the document will only be rendered as PDF
How can we implement this?
Thanks for any hints and helps!
Roland
Re: BIRT 2.5.1: TOC of Headings in PDF [message #510564 is a reply to message #510167] |
Wed, 27 January 2010 20:54 |
Roland,
I know there is a bug logged for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=132895
As a work around you may want to look at using iText on the generated
output report.
http://www.1t3xt.info/examples/browse/?page=example&id=3 80
Jason
Roland Weiss wrote:
> Hi there
> Word):
> Thanks for any hints and helps! ;)
> Roland
FUDForum. Page generated in 0.03552 seconds
