BIRT 2.5.1: Reset page numbering in PDF [message #510102] |
Tue, 26 January 2010 14:42 |
Hi There
Yes, I've seen this topic discussed many times so far. But any suggested solution works "except if you're generating PDF".
So (once again): Dos anybody has a solution for the following problem?
We have a report on which the page numbering should start on the third page with "Page 1". The first two pages are some sort of title pages.
And yes, we do have "logical" pages that get rendered on several pages in the PDF.
If we do not find a solution for this, we will have to post-process the PDF with iText or switch to another rendering technology (e.g. FOP).
Thanks for any hint!
Roland
Re: BIRT 2.5.1: Reset page numbering in PDF [message #510517 is a reply to message #510102] |
Wed, 27 January 2010 16:45 |
Roland,
Can you give some more details? Are you using the RE API or the Viewer
and what version of BIRT are you using?
Jason
Roland Weiss wrote:
> Hi There
> solution works "except if you're generating PDF". :(
> in the PDF.
> Roland
Re: BIRT 2.5.1: Reset page numbering in PDF [message #510520 is a reply to message #510517] |
Wed, 27 January 2010 17:16 |
Hi Jason
We're using BIRT 2.5.1.
We're using the Designer to create the Template-Design and render it with the JAVA-API.
But I think this is not that relevant for this question, because I do not know how to create the Tempalte-Design that could behave as described in my post.
E.g. can I achieve this by working with several Master Pages? or do I need to add some scripting? ....
Please let me know if my question is still unclear.
Roland
Re: BIRT 2.5.1: Reset page numbering in PDF [message #510563 is a reply to message #510520] |
Wed, 27 January 2010 20:52 |
Roland,
If you are using a run task and then a render task, you should be able
to use the page scripts to renumber the pages. If you set the page
break interval to a value that produces tables that are smaller than the
pdf pages the html pages and pdf pages will be the same. take a look at
this example. Look at the onPageEnd and table onPageBreak scripts.
Notice I set the page break interval on the table to 30.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.1.v20090903 Build <2.5.1.v20090917-1447></property>
<property name="units">in</property>
<method name="onPageEnd"><![CDATA[if(
reportContext.getPersistentGlobalVariable("pg") != null ){
reportContext.setPageVariable("newPageNumber",
reportContext.getPersistentGlobalVariable("pg"));
}]]></method>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="6">
</style>
<style name="table-header" id="43">
<property name="backgroundColor">#6078BF</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="table-footer" id="44">
</style>
<style name="table-detail" id="45">
<property name="backgroundColor">#E6ECFF</property>
<property name="fontSize">x-small</property>
<property name="color">#000080</property>
</style>
<style name="table-group-header-1" id="46">
<property name="backgroundColor">#809FFF</property>
</style>
<style name="table-group-footer-1" id="47">
</style>
<style name="special-header" id="48">
<property name="fontSize">medium</property>
</style>
<style name="crosstab-detail" id="49">
</style>
<style name="crosstab-header" id="50">
</style>
<style name="mydata" id="51">
<property name="color">orange</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-header>
<auto-text id="86">
<property name="type">page-variable</property>
<property name="pageVariable">newPageNumber</property>
</auto-text>
</page-header>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="52">
<property name="pageBreakAfter">always</property>
<column id="53"/>
<column id="54"/>
<column id="55"/>
<row id="56">
<cell id="57"/>
<cell id="58"/>
<cell id="59"/>
</row>
<row id="60">
<cell id="61"/>
<cell id="62">
<label id="68">
<text-property name="text">Test 1st
Page</text-property>
</label>
</cell>
<cell id="63"/>
</row>
<row id="64">
<cell id="65"/>
<cell id="66"/>
<cell id="67"/>
</row>
</grid>
<grid id="69">
<column id="70"/>
<column id="71"/>
<column id="72"/>
<row id="73">
<cell id="74"/>
<cell id="75"/>
<cell id="76"/>
</row>
<row id="77">
<cell id="78"/>
<cell id="79">
<label id="85">
<text-property name="text">Test 2nd
</label>
</cell>
<cell id="80"/>
</row>
<row id="81">
<cell id="82"/>
<cell id="83"/>
<cell id="84"/>
</row>
</grid>
<table id="9">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<method
name="onPageBreak"><![CDATA[importPackage(Packages.java.lang);
if( reportContext.getPersistentGlobalVariable("pg") == null ){
reportContext.setPersistentGlobalVariable("pg", new Integer(1));
}else{
var npg = parseInt(reportContext.getPersistentGlobalVariable("pg")) + 1;
reportContext.setPersistentGlobalVariable("pg", new Integer(npg));
}]]></method>
<property name="pageBreakInterval">30</property>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="13">
<label id="14">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="15">
<label id="16">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="17">
<label id="18">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="19">
<label id="20">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="21">
<cell id="22">
<data id="23">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="24">
<data id="25">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="26">
<data id="27">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="28">
<data id="29">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="30">
<data id="31">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="32">
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
</row>
</footer>
</table>
</body>
<property name="pageVariables">
<variable-element name="newPageNumber">
<expression name="value" type="javascript">""</expression>
<property name="type">page</property>
</variable-element>
</property>
</report>
Roland Weiss wrote:
> Hi Jason
> with the JAVA-API.
> Roland
FUDForum. Page generated in 0.03643 seconds
