Home » Language IDEs » Java Development Tools (JDT) » Project facet "Java" value 5.0 doesn't match JDK 1.6
Project facet "Java" value 5.0 doesn't match JDK 1.6 [message #508651] Tue, 19 January 2010 12:43 Go to next message
In Eclipse 3.5.1, I have a project with compiler compliance level of 1.6. I noticed a red X on the project, and the only thing I found was in the Problems view, where it said:
"Java compiler level does not match the version of the installed Java project facet."
In "Project Facets", the "Java" facet is set to "5.0". The only other value choices are "1.3" and "1.4".
Re: Project facet "Java" value 5.0 doesn't match JDK 1.6 [message #508734 is a reply to message #508651] Tue, 19 January 2010 20:55 Go to previous message
> project facet."
Sounds like maybe you are running Eclipse with a 1.5 JVM, or maybe you had a 1.6
JDK in the workspace and the location changed? It may not be able to load some
Java 6 features in that case.
Anything in the error log?
Previous Topic:Source attachment looks fine, but Eclipse can't find the source
Next Topic:Disable automatic workspace build, but compile *.java to default output folder?
Current Time: Wed Mar 19 03:32:46 EDT 2025
Powered by FUDForum. Page generated in 0.06737 seconds
