Report problem with SqlServer 2008, BIRT 2.5.1 [message #508539] |
Tue, 19 January 2010 11:35 |
Missing name Missing name Messages: 94 Registered: November 2009 |
Member |
I have a report that works with MS SQL 2008 in RCP designer but fails when deployed to tomcat. I receive the following error:
19-Jan-2010 11:19:33 org.eclipse.birt.report.engine.api.impl.RunTask doRun
SEVERE: Error happened while running the report.
java.lang.IllegalAccessError: tried to access method com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.<init>(Lcom/microsoft/sqlserver/jdbc/SQLS
erverConnection;Ljava/lang/String;II)V from class com.microsoft.sqlserver.jdbc.SQLServerConnection
at com.microsoft.sqlserver.jdbc.SQLServerConnection.prepareStatement(SQLServerConnection.java:1864)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.prepareStatement(SQLServerConnection.java:1566)
at org.eclipse.birt.report.data.oda.jdbc.Statement.prepare(Statement.java:142)
at org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.prepare(BidiStatement.java:52)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doPrepare(OdaQuery.java:229)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.prepare(OdaQuery.java:186)
at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareOdaQuery(Connection.java:281)
at org.eclipse.birt.data.engine.odaconsumer.Connection.prepareStatement(Connection.java:181)
at org.eclipse.birt.data.engine.executor.DataSource.prepareStatement(DataSource.java:269)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.prepare(DataSourceQuery.java:270)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:350)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:337)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:448)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:144)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:511)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:139)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.doExecuteQuery(DataGenerationEngine.java:71)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:254)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1818)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:258)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:243)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:82)
It seems to be some conflict of JARs or versions would be my thoughts but i'm not sure of where the conflict could arise.
There is a similar issue running on Oracle, but DB2 works fine.
Has anyone any ideas?
thanks
[Updated on: Tue, 19 January 2010 11:36] Report message to a moderator
Re: BIRT report with SqlServer 2008 [message #508627 is a reply to message #508539] |
Tue, 19 January 2010 16:23 |
Trevor,
Where do you have the ms sql jar located? Do you have it in more than
one place in your deployed environment?
Jason
TREVOR.HIGGINS@FINEOS.COM wrote:
> com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.<init >(Lcom/microsoft/sqlserver/jdbc/SQLS
> at
> com.microsoft.sqlserver.jdbc.SQLServerConnection.prepareStat ement(SQLServerConnection.java:1864)
> at
> com.microsoft.sqlserver.jdbc.SQLServerConnection.prepareStat ement(SQLServerConnection.java:1566)
> at
> org.eclipse.birt.report.data.oda.jdbc.Statement.prepare(Stat ement.java:142)
> at
> org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.pre pare(BidiStatement.java:52)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.doPrepare(OdaQuery.java:229)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.prepare(OdaQuery.java:186)
> at
> org.eclipse.birt.data.engine.odaconsumer.Connection.prepareO daQuery(Connection.java:281)
> at
> org.eclipse.birt.data.engine.odaconsumer.Connection.prepareS tatement(Connection.java:181)
> at
> org.eclipse.birt.data.engine.executor.DataSource.prepareStat ement(DataSource.java:269)
> at
> org.eclipse.birt.data.engine.executor.DataSourceQuery.prepar e(DataSourceQuery.java:270)
> at
> org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu eryExecutor.prepareOdiQuery(PreparedOdaDSQuery.java:350)
> at
> org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecu tion(QueryExecutor.java:337)
> at
> org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:448)
> at
> org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.pr oduceQueryResults(PreparedDataSourceQuery.java:190)
> at
> org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:178)
> at
> org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute (PreparedOdaDSQuery.java:144)
> at
> org.eclipse.birt.report.data.adapter.impl.DataRequestSession Impl.execute(DataRequestSessionImpl.java:511)
> at
> org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:139)
> at
> org.eclipse.birt.report.engine.data.dte.DataGenerationEngine .doExecuteQuery(DataGenerationEngine.java:71)
> at
> org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:254)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1818)
> at
> org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:80)
> at
> org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:62)
> at
> org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
> at
> org.eclipse.birt.report.engine.internal.executor.emitter.Rep ortItemEmitterExecutor.execute(ReportItemEmitterExecutor.jav a:46)
> at
> org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:65)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
> at
> org.eclipse.birt.report.engine.presentation.ReportDocumentBu ilder.build(ReportDocumentBuilder.java:258)
> at
> org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:243)
> at
> org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:82)
> thanks
Re: Report problem with SqlServer 2008, BIRT 2.5.1 [message #508710 is a reply to message #508655] |
Tue, 19 January 2010 22:58 |
Trevor,
Does it make a difference if you move the driver to the web-inf/lib
directory?
Jason
> Its in the drivers directory under the jdbc plugin. It seems to be
> related to the doing of a query as follows:
> PreparedStatement domainStmt = dbConnection.prepareStatement(
> "select id from table where NAME LIKE ?");
> This query is done in our report manager java class before it pre-loads
> reports, if there is a particular type of report parameter where we need
> to retrieve its id from its name. However, I think any database
> interaction during startup will cause it, as it happens trying to
> prepare a SQL statement. This was previously working on Websphere with
> BIRT 2.3.1 runtime.
FUDForum. Page generated in 0.04624 seconds
