Report Designer - cannot select a partial visible element [message #505833] |
Tue, 05 January 2010 10:06 |
tero Messages: 58 Registered: July 2009 |
Member |
If I do a mouse-over over an element (i.e. a table) which is bigger than its container (i.e. a grid),
I can see the label table "floating" somewhere under that grid, but I cannot select it (by clicking on that label).
As soon as I am not over that table the label disappear.
If I click during that label is displaying, the table-row is selected (I need the table to be selected).
A workaround is to "temporarily" make the grid bigger enough to see the complete table but this is very time consuming since:
- I have a lot of such grids-tables configured
- The formatting of those is very difficult because this has to fit a determined page size (small changes causing page-overflow)
- If I forgot how big the grid was, I have to start calculating the correct size again
- The formatting in the viewer is different then for example downloading it as a power-point file, therefore the formatting has to be checked on both formats
The should be an easier way to select such partially displayed elements in the Report Designer...
I tried typing the element ID on the ID field in the Properties tab to "jump" to that element (since I need it there in the properties tab), but that field is read-only.
Any other ideas?
Thanks!
[Updated on: Tue, 05 January 2010 10:09] Report message to a moderator
Re: Report Designer - cannot select a partial visible element [message #506025 is a reply to message #505833] |
Tue, 05 January 2010 14:22 |
Tero,
Use the outline view to select the table. Should be bottom left.
Jason
tero wrote:
> Hello,
> its container (i.e. a grid), I can see the label table "floating"
> label).
> complete table but this is very time consuming since: - I have a lot of
> - the formatting of those is very difficult because this has to fit a
> - The formatting in the viewer is different then for example when
> Any other ideas?
> Thanks!
FUDForum. Page generated in 0.03802 seconds
