Home » Modeling » EMF » how to install teneo
how to install teneo [message #505810] Tue, 05 January 2010 08:32 Go to next message
shuihangdong  is currently offline shuihangdong Friend
i have downloaded the teneo 1.2.0m4 version ,but have trouble to install it ,may be i don't know how to unpack the .jar.pack files, who can help me ?
Re: how to install teneo [message #505817 is a reply to message #505810] Tue, 05 January 2010 09:09 Go to previous message
Martin Taal is currently offline Martin TaalFriend
Hi shuihangdong.
Have you placed the zip file into the dropins directory and then restarted eclipse? Or updated through the update managaer?
Note that 1.2.0M4 is for Eclipse 3.6.0 (Helios). If you are using 3.5 then you should use the Teneo 1.1.* builds.
You should not unpack the jar files, the download is a zip file which can be unpacked (but not the jar file inside).
gr. Martin
> can help me ?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:Reading ecore causes stack overflow
Next Topic:EMF 2.6 M4 EObject.eContainer()
Current Time: Wed May 27 06:25:17 GMT 2020
Powered by FUDForum. Page generated in 0.01722 seconds
