Home » Archived » BIRT » reusing data sets(data sets)
reusing data sets [message #504954] Wed, 23 December 2009 13:49 Go to next message
Shayne Paddock is currently offline Shayne PaddockFriend
When I create reports I typically insert thumbnail graphics in the header to return the report in PDF or Excel format. On the images I configure the hyperlink as a drill-through and configure all the same parameters and the web version.
This works OK in most cases but is a real pain when data sets take a while to run. Is there a way to reuse the data set from the web version?
I see an option to configure "report document" but the document gets built with a unique name and runtime so I wouldn't know how to reference it.
Reusing data sets would also be helpful for drilling down to reports that would use them as well.
Any help in this would be greatly appreciated.
Kindest regards,
Shayne
Re: reusing data sets [message #504961 is a reply to message #504954] Wed, 23 December 2009 19:34 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Shayne,
You could always use a beforeFactory script to get the value in a
JavaScript variable like
myjsvar =
reportContext.getHttpServletRequest().getAttribute("attributeBean ").getReportDocumentName();
Make sure to not use the var keyword to make it global. Also realize
this only works when using 2 processes instead of 1 to generate the
report. This happens with a /frameset url but not with a /run as no
report document is created when using one process.
Jason
> it.
> Kindest regards,
> Shayne
Previous Topic:Removing unused data column bindings from XML source.
Next Topic:crosstab data cube w/ xml data source problem
Current Time: Tue Apr 16 13:20:37 GMT 2024
Powered by FUDForum. Page generated in 0.19437 seconds
