Integrating BIRT and EMF Ecore [message #504450] |
Sat, 19 December 2009 13:27 |
We will soon be looking to use BIRT as the reporting engine for our EMF driven framework ORMF. I am aware that there is a Ecore ODA driver available. What I would very much appreciate are the experiences of this forum on using it or other means to integrate EMF and BIRT. What are the issues? Any tips or advice would be very much appreciated.
Many thanks,
Joel
Re: Integrating BIRT and EMF Ecore [message #504625 is a reply to message #504450] |
Mon, 21 December 2009 20:22 |
Joel,
In addition to that driver you can always use a scripted data source to
access the model using the emf APIs.
Jason
Joel Rosi-Schwartz wrote:
> driven framework http://eclipse.org/ormf/ I am aware that there is a
> http://wiki.eclipse.org/Ecore_ODA_Driver available. What I would very
> Many thanks,
> Joel
Re: Integrating BIRT and EMF Ecore [message #504630 is a reply to message #504625] |
Mon, 21 December 2009 20:40 |
Hi Jason,
I am new to integrating with BIRT. Can you possibly point me towards documentation/information the would elucidate how to use a scripted data source with EMF. I have both of the BIRT books so just referencing chapter(s) would be very helpful.
Many thanks,
Joel
Jason Weathersby wrote on Mon, 21 December 2009 20:22 | Joel,
Jason
Re: Integrating BIRT and EMF Ecore [message #504638 is a reply to message #504630] |
Mon, 21 December 2009 20:57 |
Joel,
There is a chapter on using scripted data sources. This is where you
need to look. There are several dev share items at BIRT Exchange on
using them.
http://www.birt-exchange.org/modules/wfdownloads/devshare.ph p?filtercontent=scripted+data&contenttype=-1&date=-2 year&rating=0&results=10&cid=0
Remember you can write them in Java or JavaScript. If you write them in
JavaScript remember to import the required packages like:
importPackage(Packages.java.lang);
myjsvar = new Integer(5);
Jason
> Hi Jason,
> Many thanks,
> Joel
>> Joel,
>> to access the model using the emf APIs.
>> Jason
Re: Integrating BIRT and EMF Ecore [message #504643 is a reply to message #504638] |
Mon, 21 December 2009 21:15 |
Jason, got'ya, thanks for the pointers - Joel
Jason Weathersby wrote on Mon, 21 December 2009 20:57 | Joel,
using them.
Jason
> Hi Jason,
> Many thanks,
> Joel
>> Joel,
>> Jason
Re: Integrating BIRT and EMF Ecore [message #504651 is a reply to message #504643] |
Mon, 21 December 2009 21:53 |
Joel,
Just continue this thread if you run into issues.
Jason
>> Joel,
>> using them.
>> in JavaScript remember to import the required packages like:
>> Jason
>> > Hi Jason,
>> towards > documentation/information the would elucidate how to use a
>> scripted data > source with EMF. I have both of the BIRT books so
>> just referencing > chapter(s) would be very helpful.
>> > > Many thanks,
>> > Joel
>> >> Joel,
>> source >> to access the model using the emf APIs.
>> >> Jason
FUDForum. Page generated in 0.02386 seconds
