Home » Archived » BIRT » Perform sorting based on user input
Perform sorting based on user input [message #503331] Fri, 11 December 2009 17:36 Go to next message
Neil Wang is currently offline Neil WangFriend
I am exploring possibilities to sort based on user input.
For example, when we run a report, the parameter dialog shows up and it has two radio buttons "Ascending" and "Descending". User can pick either button to decide how a field will be sorted.
I know how to define the parameter but do not know how to use it to sort. please advise.
Re: Perform sorting based on user input [message #503348 is a reply to message #503331] Fri, 11 December 2009 21:06 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Neil,
You can always define the sort in the beforeFactory
importPackage(Packages.org.eclipse.birt.report.model.api);
importPackage(Packages.org.eclipse.birt.report.model.api.ele ments);
importPackage(Packages.com.ibm.icu.util);
importPackage(Packages.org.eclipse.birt.data.engine.api);
delm = reportContext.getDesignHandle().findElement("mytable");
sc = StructureFactory.createSortKey();
sc.setKey("row[\"ORDERNUMBER\"]");
sc.setDirection(params["mysortdirection"].value);
ph = delm.getPropertyHandle(TableHandle.SORT_PROP);
ph.addItem(sc);
or modify an existing one like:
delm = reportContext.getDesignHandle().findElement("mytable2");
//get number or iterate
sk = ph.get(0);
sk.setDirection(params["mysortdirection"].value);
the parameter mysortdirection needs to be either desc or asc.
Jason
Neil Wang wrote:
Re: Perform sorting based on user input [message #503787 is a reply to message #503348] Tue, 15 December 2009 18:59 Go to previous messageGo to next message
Thank you for your reply. This is what I have done:
1. I have this in the beforeFactory script.
delm = reportContext.getDesignHandle().findElement("Package");
sc.setDirection(params["SortDirection"].value);
ph.addItem(sc);
and this is what I got:
The following items have errors:
Table Package:
- Fail to compute value from sort, group or filter expression.
A BIRT exception occurred: There are errors evaluating script "row[ORDERNUMBER"]"; Invalid bound column name: ORDERNUMBER
Caused by: org.mozilla.javascript.EvaluatorException: Invalid bound column name: ORDERNUMBER.
please advise.
Re: Perform sorting based on user input [message #503802 is a reply to message #503787] Tue, 15 December 2009 20:50 Go to previous messageGo to next message
Neil,
Select the table in the design you are trying to change sorting on.
Next select the binding tab next to properties. This list all of the
columns you can sort on. Is ORDERNUMBER in this list?
Jason
Neil Wang wrote:
> ph.addItem(sc);
> Table Package:
> please advise.
Re: Perform sorting based on user input [message #503847 is a reply to message #503802] Tue, 15 December 2009 19:42 Go to previous messageGo to next message
Hi Jason,
I don't have "ORDERNUMBER" in any of the data set. One of the data sets is called "Package" and there is a table called "Package" in the layout. My goal is to be able to sort the entries in the detail row of the "Package" table. I can definitely add a field called "ORDERNUMBER" under the "Package" data set and establish a binding between "ORDERNUMBER" and the "Package" table in the layout. Should I do this? If yes, what value should it have?
Also, I am using BIRT 2.3.2.
please advise.
Re: Perform sorting based on user input [message #503857 is a reply to message #503847] Wed, 16 December 2009 00:18 Go to previous messageGo to next message
Neil,
Swap
with whatever column you want to sort on
sc.setKey("row[\"MYCOL\"]");
Jason
Neil Wang wrote:
> Hi Jason,
> should it have?
> please advise.
Re: Perform sorting based on user input [message #503994 is a reply to message #503857] Wed, 16 December 2009 18:34 Go to previous message
It works. Thank you very much.
Previous Topic:BIRT Master page
Next Topic:Rounding behaviour BIRT and Excel
Current Time: Tue Apr 16 10:36:28 GMT 2024
Powered by FUDForum. Page generated in 0.08105 seconds
