Home » Language IDEs » Java Development Tools (JDT) » Custom Wizard use in Eclipse(Custom Wizard Help)
Custom Wizard use in Eclipse [message #501735] Thu, 03 December 2009 11:06 Go to next message
I used an RCP tutorial to extend the new java project wizard. The wizard works fine when it is used as standalone, but it does not show up when I want to use it with another wizard.
For example, I want to check out a project using CVS and then select the option to create a project using the new project wizard. The default project wizards show up, but not my custom project wizard.
How can I make Eclipse 'see' the custom wizard from this scenario?
Eddie
Re: Custom Wizard use in Eclipse [message #503465 is a reply to message #501735] Mon, 14 December 2009 01:06 Go to previous message
This should just work. If not, please file a bug report against Platform
UI with steps to reproduce (attach your wizard).
Dani
> Thanks
> Eddie
Previous Topic:Ali
Next Topic:Packaging .txt, .doc, and images into a runnable jar
Current Time: Sun Mar 23 05:14:19 EDT 2025
Powered by FUDForum. Page generated in 0.03863 seconds
