Home » Language IDEs » PHP Development Tools (PDT) » HTML and PHP mixed content
HTML and PHP mixed content [message #501083] Mon, 30 November 2009 22:52 Go to next message
Bryan Mising name is currently offline Bryan Mising nameFriend
Hi everyone here is an easy question for you. For security reasons I have a website that consist of only .htm files. I have set my Apache server to parse .htm as PHP content.
If I have the following code block.
<html>
<head>
<title>Test</title>
</head>
<body>
print("hello world");
</body>
</html>
I see that the HTML content is color coded by PDT and I can do formatting and validation on the HTML code.
But the PHP code embedded in the HTML is not color coded and I cannot format the code. PDT simply thinks it is plain text or something.
How to I set PDT to parse both the HTML code and the PHP code at the same time in a .htm file?
thanks
Re: HTML and PHP mixed content [message #501100 is a reply to message #501083] Tue, 01 December 2009 03:33 Go to previous messageGo to next message
Lichi G is currently offline Lichi GFriend
You can change the associated editor for *.htm files, assigning the PHP Editor instead of the HTML Editor.
You should go: Preferences > Editors > File Associations
Regards.
Re: HTML and PHP mixed content [message #501342 is a reply to message #501100] Tue, 01 December 2009 21:46 Go to previous messageGo to next message
Well, then only the PHP code will be formatted and the HTML code will not, correct?
My question was how do I get the editor to parse both PHP and HTML code at the same time?
I can't imagine that I am the first one on the planet to put embedded PHP code inside HTML code.
thanks
Re: HTML and PHP mixed content [message #501363 is a reply to message #501342] Tue, 01 December 2009 23:26 Go to previous message
Bryan wrote on Tue, 01 December 2009 16:46
NO. that is not correct. The PHP Editor also support HTML syntax formating.
The PHP Editor will treat as PHP everything inside a php block "<? ... ?>" and
it will treat as HTML everything else outside of the php block.
Previous Topic:"org.eclipse.ui.ide.workbench" could not be found in the registry
Next Topic:Using PDT's parser outside of the IDE
Current Time: Wed May 05 23:09:55 GMT 2021
Powered by FUDForum. Page generated in 0.01521 seconds
