Re: managment of blank tables [message #499752] |
Mon, 23 November 2009 22:37 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
On 11/23/09 1:33 PM, francisco wrote:
> Hi, im a new commer, i need some help with a report im working on.
> the problem is that i made a sumatorie of the values on a row, and it
> return the sum without problems, but when I have a table that dont
> present any register it dont return me any value, but i need to display
> 0 instead, i add a image to show the problem im having, the value that
> appears there correspond to reembolsables not to movilizacion
If this is related to BIRT, you should post the question to the BIRT
group. I've copied it to there (eclipse.birt for NNTP readers).
Hope this helps,
Eric
Re: managment of blank tables [message #500007 is a reply to message #499752] |
Tue, 24 November 2009 17:00 |
Can you post the report?
> Hope this helps,
> Eric
FUDForum. Page generated in 0.04152 seconds
