Home » Archived » XML Schema Definition (XSD) » Traversing a schema
Traversing a schema [message #50608] |
Wed, 18 August 2004 20:10  |
Originally posted by: gj.puredge.com
I'm sure this is a total newbie question but I'm still oretty new to the
Schema Infoset Model and am having a little trouble wrapping my brain around
it so I'm taking it one step at a time and hopefully don't annoy people too
much with these simple questions. I'm afraid this is a little long so
please bear with me. I promise to write a "XML Schema Infoset Model for
Idiots" article when this is all done to avoid this in the future :)
I mentioned in another post that I process all the element declarations in a
schema like this:
EList elements = schema.getSchema().getElementDeclarations()
for (Iterator iter = elements.iterator(); iter.hasNext(); )
XSDElementDeclaration element = (XSDElementDeclaration)iter.next();
// do something with the element
So if I come to something like this:
<xsd:element name="Start">
<xsd:complexType>
<xsd:choice>
<xsd:element name="item1" type="xsd:string</xsd:element>
<xsd:element name="item2" type="xsd:string</xsd:element>
</xsd:choice>
</xsd:complexType>
</xsd:element>
The object "element" will contain the XSDElementDeclaration for the schema
element "Start". I can even see the name of this element (Start) using
element.getName();
Here's where things get a little hairy for guys like me who are just
starting out with the schema model. Could someone please let me know when I
go off the rails?
At this point I've got my "element" object which contains the schema element
named "Start". Now I know that a schema element can be either a simple or
complex type. If it is a simple type I don't need to go much further for
now. If it is a complex type I need to do some further processing to get
the contents.
I check if the element is a complexType:
XSDParticle particle = type.getComplexType();
If I get back null that means the element is a simple type. In this example
I get back a particle which tells me I have a complex type.
So I obtain the contents of the complex type:
XSDParticleContent content = particle.getContent();
To me this means I'm sitting right about here in the schema:
--> <xsd:choice>
</xsd:choice>
That's where I get lost. I know that I should be able to see the
<xsd:choice> element as some item in "content" but I do not know where to
find it.
Could anyone give me a few pointers?
Gary
Re: Traversing a schema [message #50667 is a reply to message #50608] |
Thu, 19 August 2004 06:46   |
--------------090009000505070705070706
Content-Type: text/plain; charset=us-ascii; format=flowed
Gary,
Because XSD represents both the concrete syntax of XML Schema and the
abstract component model defined in the XML Schema spec, you can analyze
the particle structure either according to its syntax or according to
it's component structure. From a concrete point of view, a particle
has content of type XSDParticleContent, which can either be a model
group, a wildcard, an element declaration, or a model group definition.
If it's an element declaration or model group definition, you have to be
sure to get the resolved element declaration / resolved model group
definition to walk from the object representing the "ref" to the actual
object where it is declared/defined (and given the model group
definition, you need to walk to it's model group). From an abstract
point of view, a particle has a term, which is either a model group, a
wildcard or an element declaration, i.e., all the above walking has
already been done. This structure is recursive on model group which has
concrete contents and abstract particles, both of which represent more
particles. Something like this is probably what you want to do
public void visit(XSDParticle xsdParticle)
XSDTerm xsdTerm = xsdParticle.getTerm();
if (xsdTerm instanceof XSDModelGroup)
XSDModelGroup xsdModelGroup = (XSDModelGroup)xsdTerm;
for (Iterator i = xsdModelGroup.getParticles().iterator();
i.hasNext(); )
visit((XSDParticle)i.next());
else if (xsdTerm instanceof XSDWildcard)
XSDWildcard xsdWildcard = (XSDWildcard)xsdTerm;
else
XSDElementDeclaration xsdElementDeclaration =
(XSDElementDeclaration)xsdTerm;
>schema like this:
> <xsd:complexType>
> <xsd:choice>
> </xsd:choice>
> </xsd:complexType>
> </xsd:element>
>element.getName();
>go off the rails?
>the contents.
>--> <xsd:choice>
> </xsd:choice>
>find it.
>Thanks
>Gary
Content-Type: text/html; charset=us-ascii
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
analyze the particle structure either according to its syntax or
according to it's component structure. From a concrete point of
view, a particle has content of type XSDParticleContent, which can
either be a model group, a wildcard, an element declaration, or a model
group definition. If it's an element declaration or model group
definition, you have to be sure to get the resolved element declaration
/ resolved model group definition to walk from the object representing
the "ref" to the actual object where it is declared/defined (and given
the model group definition, you need to walk to it's model group).
From an abstract point of view, a particle has a term, which is either
a model group, a wildcard or an element declaration, i.e., all the
above walking has already been done. This structure is recursive on
model group which has concrete contents and abstract particles, both of
which represent more particles. Something like this is probably what
you want to do<br>
<blockquote><small>public void visit(XSDParticle xsdParticle)<br>
{<br>
XSDTerm xsdTerm = xsdParticle.getTerm();<br>
if (xsdTerm instanceof XSDModelGroup)<br>
{<br>
XSDModelGroup xsdModelGroup = (XSDModelGroup)xsdTerm;<br>
i.hasNext(); )<br>
{<br>
visit((XSDParticle)i.next());<br>
}<br>
}<br>
else if (xsdTerm instanceof XSDWildcard)<br>
{<br>
XSDWildcard xsdWildcard = (XSDWildcard)xsdTerm;<br>
}<br>
else<br>
{<br>
(XSDElementDeclaration)xsdTerm;<br>
}<br>
}</small><br>
</blockquote>
Gary J wrote:<br>
<blockquote cite="midcg0r14$qu2$1@eclipse.org" type="cite">
<pre wrap="">I'm sure this is a total newbie question but I'm still oretty new to the
schema like this:
<xsd:complexType>
<xsd:choice>
</xsd:choice>
</xsd:complexType>
</xsd:element>
element.getName();
go off the rails?
the contents.
--> <xsd:choice>
</xsd:choice>
find it.
Gary
</pre>
</blockquote>
<br>
</body>
</html>
--------------090009000505070705070706--
Re: Traversing a schema [message #50749 is a reply to message #50667] |
Thu, 19 August 2004 15:09   |
I think I answered part of my own question. I was only checking Element
declarations, not types. I'm now checking both and get back a larger list
for "comments".
Is there any documentation about what I should be seeing in these lists?
Here's my code:
EList elements = schema.getSchema().getElementDeclarations();
EList types = schema.getSchema().getTypeDefinitions();
for (Iterator iter = elements.iterator(); iter.hasNext();)
System.out.println(" Element: " + element.getName());
ArrayList elist = (ArrayList)UsageCrossReferencer.find(element,
elements);
// list contents of element references
for (Iterator i = elist.iterator(); i.hasNext();)
Object obj = i.next();
System.out.println(" Element ref: " + obj.getClass());
ArrayList tlist = (ArrayList)UsageCrossReferencer.find(element, types);
// list contents of type references
for (Iterator i = tlist.iterator(); i.hasNext();)
System.out.println(" Type ref: " + obj.getClass());
Here's what I get:
For the "comment" element I get:
Element: comment
Element ref: class org.eclipse.emf.ecore.impl.BasicEObjectImpl$2
Element ref: class org.eclipse.emf.ecore.util.EObjectEList
Type ref: class org.eclipse.emf.ecore.impl.BasicEObjectImpl$2
For the "purchaseOrder" element I get:
Element: purchaseOrder
How do I decode all this?
Gary
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:cg20aa$hot$1@eclipse.org...
Gary,
abstract component model defined in the XML Schema spec, you can analyze the
particle structure either according to its syntax or according to it's
component structure. From a concrete point of view, a particle has
content of type XSDParticleContent, which can either be a model group, a
wildcard, an element declaration, or a model group definition. If it's an
element declaration or model group definition, you have to be sure to get
the resolved element declaration / resolved model group definition to walk
from the object representing the "ref" to the actual object where it is
declared/defined (and given the model group definition, you need to walk to
it's model group). From an abstract point of view, a particle has a term,
which is either a model group, a wildcard or an element declaration, i.e.,
all the above walking has already been done. This structure is recursive on
which represent more particles. Something like this is probably what you
want to do
i.hasNext(); )
else
schema like this:
<xsd:complexType>
<xsd:choice>
</xsd:choice>
</xsd:complexType>
</xsd:element>
element.getName();
go off the rails?
the contents.
--> <xsd:choice>
</xsd:choice>
find it.
Gary
Re: Traversing a schema [message #50798 is a reply to message #50749] |
Thu, 19 August 2004 15:17   |
Sorry, this was posted to the wrong thread.
"Gary J" <gj@puredge.com> wrote in message news:cg2tol$7ih$1@eclipse.org...
> for "comments".
> Here's my code:
> elements);
> for (Iterator i = e
> Here's what I get:
> Element: comment
> Thanks
> Gary
> Gary,
the
to
term,
on
> want to do
> i.hasNext(); )
> else
around
too
a
> schema like this:
> <xsd:complexType>
> <xsd:choice>
> </xsd:choice>
> </xsd:complexType>
> </xsd:element>
> element.getName();
I
> go off the rails?
element
> the contents.
example
> --> <xsd:choice>
> </xsd:choice>
> find it.
> Thanks
> Gary
Re: Traversing a schema [message #51048 is a reply to message #50667] |
Fri, 20 August 2004 13:09   |
I'm just getting into this now. When I walk the schema I'm starting with
the Element Declarations and determining the type of each element with
element.getTypeDefinition() from which I will get the Particle if the type
is complex. I can then get the Term and process as you suggested.
I noticed that there are some situations when getTypeDefinition() returns
null. One case is when the element is a reference, ie: ref= . If I don't
get back a type, how can I traverse the elements if the referenced item is a
complex element?
Are there other situations when getTypeDefinition() returns a null?
I'm slowly chewing my way through Part 1 but its not easy going :)
Gary,
want to do
i.hasNext(); )
else
schema like this:
<xsd:complexType>
<xsd:choice>
</xsd:choice>
</xsd:complexType>
</xsd:element>
element.getName();
go off the rails?
the contents.
--> <xsd:choice>
</xsd:choice>
find it.
Gary
Re: Traversing a schema [message #51074 is a reply to message #51048] |
Fri, 20 August 2004 13:35   |
Gary,
If you have an XSDElementDeclaration x and
x.isElementDeclarationReference() is true, then you need to do
x.getResolvedElementDeclaration() to get the actual declaration rather
then the reference to it. If it's false, then
x.getResolvedElementDeclaration() == x, i.e., it resolves to itself.
Gary J wrote:
>Hi,
>complex element?
>Thanks
>Gary,
>want to do
>i.hasNext(); )
> else
>schema like this:
> <xsd:complexType>
> <xsd:choice>
> </xsd:choice>
> </xsd:complexType>
> </xsd:element>
>element.getName();
>go off the rails?
>the contents.
>--> <xsd:choice>
> </xsd:choice>
>find it.
>Thanks
>Gary
Re: Traversing a schema [message #51159 is a reply to message #51102] |
Mon, 23 August 2004 07:04  |
Gary,
This looks good. Yes, an anonymous type will have a null name.
Gary J wrote:
>Ed,
>Thanks for all the patient help.
>I think I have it almost figured out. I'll step through what I am doing. My
>goal is to print out a simplified schema (attributes ignored for now).
>I started with a very simple schema:
> <xsd:element name="test">
> <xsd:complexType>
> <xsd:choice>
> <xsd:element ref="comment1" minOccurs="1" maxOccurs="1"></xsd:element>
> <xsd:element ref="comment2" minOccurs="1" maxOccurs="1"></xsd:element>
> </xsd:choice>
> </xsd:complexType>
> </xsd:element>
> <xsd:element name="comment1" type="xsd:string"></xsd:element>
> <xsd:element name="comment2" type="xsd:string"></xsd:element>
></xsd:schema>
>Admittedly this is a trivial schema but it should suffice. Here's the
>traversing sequence:
>1. I start with schema.getElementDeclarations() and process each element in
>the list:
>2. I can print the element name
>System.out.println(element.getName());
>3. I determine that "test" is a complexType:
>XSDTypeDefinition type = element.getTypeDefinition().
>** Question: how do I determine this is an anonymous type? getName() returns
>null?
>4. Since this is a complexType I'll get the particle:
>5. Get the term for this particle
>XSDTerm term = particle.getTerm();
>6. In this case term is an instance of XSDModelGroup
>XSDModelGroup modelGroup = (XSDModelGroup)term;
>7. I get the compositor and print it out
>XSDCompositor c = modelGroup.getCompositor();
>System.out.println(c.getName()); // "choice"
>8. I process each particle in the modelGroup
>EList list = modelGroup.getParticles();
>8. back to 5
>9. this time the term is an instance of XSDElementDeclaration
>XSDElementDeclaration element = (XSDElementDeclaration)term;
>10. back to 2
>11. This time the element is a reference
>element.isElementDeclarationReference() is true
>element = element.getResolvedElementDeclaration();
>13. Simple type, just print name of element
>etc
>This should give me:
><test>
> <choice>
> <comment1>
> <comment2>
>(without the brackets)
>How does this look? Am I on the right track? There's a few gaps and I
>haven't even considered things like groups but its only been a week or so
>since I started this.
>Thanks
Re: Traversing a schema [message #590402 is a reply to message #50608] |
Gary,
i.hasNext(); )
else
>schema like this:
> <xsd:complexType>
> <xsd:choice>
> </xsd:choice>
> </xsd:complexType>
> </xsd:element>
>element.getName();
>go off the rails?
>the contents.
>--> <xsd:choice>
> </xsd:choice>
>find it.
>Thanks
>Gary
<html>
<head>
<title></title>
</head>
Gary,<br>
<br>
you want to do<br>
{<br>
{<br>
i.hasNext(); )<br>
{<br>
}<br>
}<br>
{<br>
}<br>
else<br>
{<br>
}<br>
}</small><br>
</blockquote>
Gary J wrote:<br>
schema like this:
<xsd:complexType>
<xsd:choice>
</xsd:choice>
</xsd:complexType>
</xsd:element>
element.getName();
go off the rails?
the contents.
--> <xsd:choice>
</xsd:choice>
find it.
Gary
</pre>
</blockquote>
<br>
</body>
</html>
Re: Traversing a schema [message #590444 is a reply to message #50667] |
for "comments".
Here's my code:
elements);
Here's what I get:
Element: comment
Gary
Gary,
want to do
i.hasNext(); )
else
schema like this:
<xsd:complexType>
<xsd:choice>
</xsd:choice>
</xsd:complexType>
</xsd:element>
element.getName();
go off the rails?
the contents.
--> <xsd:choice>
</xsd:choice>
find it.
Gary
Re: Traversing a schema [message #590466 is a reply to message #50749] |
> for "comments".
> Here's my code:
> elements);
> for (Iterator i = e
> Here's what I get:
> Element: comment
> Thanks
> Gary
> Gary,
the
to
term,
on
> want to do
> i.hasNext(); )
> else
around
too
a
> schema like this:
> <xsd:complexType>
> <xsd:choice>
> </xsd:choice>
> </xsd:complexType>
> </xsd:element>
> element.getName();
I
> go off the rails?
element
> the contents.
example
> --> <xsd:choice>
> </xsd:choice>
> find it.
> Thanks
> Gary
Re: Traversing a schema [message #590636 is a reply to message #50667] |
complex element?
Gary,
want to do
i.hasNext(); )
else
schema like this:
<xsd:complexType>
<xsd:choice>
</xsd:choice>
</xsd:complexType>
</xsd:element>
element.getName();
go off the rails?
the contents.
--> <xsd:choice>
</xsd:choice>
find it.
Gary
Re: Traversing a schema [message #590654 is a reply to message #51048] |
Gary,
Gary J wrote:
>Hi,
>complex element?
>Thanks
>Gary,
>want to do
>i.hasNext(); )
> else
>schema like this:
> <xsd:complexType>
> <xsd:choice>
> </xsd:choice>
> </xsd:complexType>
> </xsd:element>
>element.getName();
>go off the rails?
>the contents.
>--> <xsd:choice>
> </xsd:choice>
>find it.
>Thanks
>Gary
Re: Traversing a schema [message #590672 is a reply to message #50667] |
Fri, 20 August 2004 14:57  |
Ed,
<xsd:complexType>
<xsd:choice>
</xsd:choice>
</xsd:complexType>
</xsd:element>
</xsd:schema>
the list:
null?
8. back to 5
10. back to 2
etc
<test>
<choice>
<comment1>
<comment2>
Re: Traversing a schema [message #590698 is a reply to message #51102] |
Gary,
Gary J wrote:
>Ed,
> <xsd:complexType>
> <xsd:choice>
> </xsd:choice>
> </xsd:complexType>
> </xsd:element>
></xsd:schema>
>the list:
>null?
>8. back to 5
>10. back to 2
>etc
><test>
> <choice>
> <comment1>
> <comment2>
>Thanks
Current Time: Tue Jul 22 15:31:31 EDT 2025
Powered by FUDForum. Page generated in 0.05671 seconds
