Re: Conditional Visibility (for Data) not always working in the BIRT viewer [message #498404 is a reply to message #498108] |
Mon, 16 November 2009 18:38 |
Tero,
Can you reproduce the issue with the sample data and post the report?
Jason
tero wrote:
> Hello Jason + thanks for responding,
> Your Qs:
>> Is that a crosstab or a table?
> table
>> is the visibility expression on the data item?
> yes
>> column binding integer?
> yes
> In the meantime I am using a workaround, which is not elegant + prone to
> generate other kind of errors? because it needs more code on the
> front-end...
> in the data field (Data Binding):
> dataSetRow["colData1"]>0?dataSetRow["colData1"]:null;
> and since I have an Aggregation (Sum) on that column in the "Aggregation
> Builder" Expression field:
> row["colData1"]==null?0:row["colData1"];
> Not nice but producing what's requested.
> Very strange if you see the attached pictures that the Preview works but
> the Viewer not ...
> Any idea why?
> Is it still possible to get the "visibility feature" to work?
FUDForum. Page generated in 0.03423 seconds
