Re: ja debugging [message #496032 is a reply to message #495941] |
Sat, 07 November 2009 12:05 |
Hi Simon,
One interesting approach that we are looking at is to compile the script code into java bytecodes
and then use JPDA. It supports debugging non-java sources so it seems we'd get a lot for free doing
it that way. I'm not sure what the Eclipse Debug Framework brings into the equation, but I assume
that it's somehow based on JPDA?
Thomas Hallgren
Simon Kaegi wrote:
> FWIW we have the same problem in e4 and are looking at being able to support
> debugging both JavaScript(Rhino) and Java on the same stack. We do not
> currently have multi-language support for a single debug target but you can
> still debug the Java and JavaScript debug targets independently.
> -Simon
> "Henrik Lindberg" <henrik.lindberg@cloudsmith.com> wrote in message
> news:1716214770278094432.868440henrik.lindberg-cloudsmith.com@news.eclipse.org...
>> Would very much like for someone to look into how js ca be debugged
>> inline with the rest if b3 syntax. If we hand off to js, how are
>> breakpoints set for instance?
>> - henrik
Re: ja debugging [message #590559 is a reply to message #495941] |
Hi Simon,
Thomas Hallgren
> -Simon
>> - henrik
FUDForum. Page generated in 0.02867 seconds
