Home » Archived » BIRT » Tooltip performance in a SWT Chart
Re: Tooltip performance in a SWT Chart [message #492965 is a reply to message #492882] |
Thu, 22 October 2009 14:11 |
Enrico,
Any chance you can post your code?
Jason
Enrico Schnepel wrote:
> Hallo,
> I am migrating from Birt 2.3.2 to 2.5.1 and have performance issius with
> tootips in a chart in a SWT canvas in a RCP application. When adding a mouse
> over trigger with a tooltip action the time to render the chart changes by a
> magnitude of 9 (0.25 sec without the trigger and 2.2 sec with the trigger).
> What can I do to change this? With Birt 2.3.2 the performance was ok.
> Thanks in advance
> Enrico
Re: Tooltip performance in a SWT Chart [message #492983 is a reply to message #492965] |
Thu, 22 October 2009 14:52 |
Enrico Schnepel Messages: 121 Registered: July 2009 |
Thanks for your answer,
the code to add the trigger follows below:
LineSeries ls = ...;
DataPoint dp = ls.getDataPoint();
EList<DataPointComponent> components = dp.getComponents();
components.clear();
components.add(DataPointComponentImpl.create(
DataPointComponentType.SERIES_VALUE_LITERAL, null));
DataPointComponentType.ORTHOGONAL_VALUE_LITERAL,
JavaNumberFormatSpecifierImpl.create("#,##0 km/h")));
components
..add(DataPointComponentImpl.create(
DataPointComponentType.BASE_VALUE_LITERAL,
ModelFactory.eINSTANCE
..createMyJavaNumberFormatSpecifier()));
// Commenting out the following lines improves the performance
significantly.
ls.getTriggers().add(
TriggerImpl.create(TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create(ActionType.SHOW_TOOLTIP_LITERAL,
TooltipValueImpl.create(500, null))));
I have my own FormatSpecifier which is derived and implemented using
EMF/Ecore. It is also used for the X-Axis.
Best Regards
Enrico
"Jason Weathersby" <jasonweathersby@windstream.net> schrieb im Newsbeitrag
news:hbpp2a$k0k$3@build.eclipse.org...
> Enrico,
> Jason
>> Hallo,
>> mouse over trigger with a tooltip action the time to render the chart
>> changes by a magnitude of 9 (0.25 sec without the trigger and 2.2 sec
>> with the trigger). What can I do to change this? With Birt 2.3.2 the
>> performance was ok.
>> Thanks in advance
>> Enrico
Re: Tooltip performance in a SWT Chart [message #493000 is a reply to message #492983] |
Thu, 22 October 2009 16:18 |
Enrico,
I am not seeing this issue with 2.5.1. Take a look at this class that
extends a Composite that I am using in my RCP app.
package org.eclipse.birt.examples.rcpchartengine;
import java.io.FileWriter;
import java.io.PrintWriter;
import org.eclipse.birt.chart.api.ChartEngine;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.exception.ChartException;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.Generator;
import org.eclipse.birt.chart.log.ILogger;
import org.eclipse.birt.chart.log.Logger;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.ActionType;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.LineAttributes;
import org.eclipse.birt.chart.model.attribute.LineStyle;
import org.eclipse.birt.chart.model.attribute.Marker;
import org.eclipse.birt.chart.model.attribute.MarkerType;
import org.eclipse.birt.chart.model.attribute.Position;
import org.eclipse.birt.chart.model.attribute.RiserType;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.TriggerCondition;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionI mpl;
import org.eclipse.birt.chart.model.attribute.impl.TooltipValueImpl ;
import org.eclipse.birt.chart.model.attribute.impl.URLValueImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.NumberDataSet;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.TextDataSet;
import org.eclipse.birt.chart.model.data.Trigger;
import org.eclipse.birt.chart.model.data.impl.ActionImpl;
import org.eclipse.birt.chart.model.data.impl.NumberDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.data.impl.TextDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.TriggerImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.BarSeries;
import org.eclipse.birt.chart.model.type.LineSeries;
import org.eclipse.birt.chart.model.type.impl.BarSeriesImpl;
import org.eclipse.birt.chart.model.type.impl.LineSeriesImpl;
import org.eclipse.birt.core.framework.PlatformConfig;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.ControlEvent;
import org.eclipse.swt.events.ControlListener;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Shell;
public class SwtLiveChartViewer extends Composite implements
PaintListener, ControlListener
private IDeviceRenderer idr = null;
private Chart cm = null;
private GeneratedChartState gcs = null;
public static SwtLiveChartViewer c3dViewer;
* Used in building the chart for the first time
private boolean bFirstPaint = true;
* execute application
* @param args
public static void main( String[] args )
Display display = Display.getDefault( );
Shell shell = new Shell( display, SWT.CLOSE );
shell.setSize( 600, 400 );
shell.setLayout( new GridLayout( ) );
c3dViewer = new SwtLiveChartViewer( shell, SWT.NO_BACKGROUND );
c3dViewer.setLayoutData( new GridData( GridData.FILL_BOTH ) );
c3dViewer.addPaintListener( c3dViewer );
c3dViewer.addControlListener( c3dViewer );
shell.open( );
while ( !shell.isDisposed( ) )
if ( !display.readAndDispatch( ) )
display.sleep( );
display.dispose( );
public void dispose() {
if( (imgChart !=null) && (!imgChart.isDisposed()))imgChart.dispose();
if( (gcImage !=null) && (!gcImage.isDisposed()))gcImage.dispose();
super.dispose();
* Constructor
SwtLiveChartViewer( Composite parent, int style )
super( parent, style );
try
PlatformConfig config = new PlatformConfig( );
config.setBIRTHome("");
idr = ChartEngine.instance( config ).getRenderer( "dv.SWT" );
idr.setProperty( IDeviceRenderer.UPDATE_NOTIFIER, this );
catch ( ChartException pex )
pex.printStackTrace();
cm = createLiveChart( );
public static final Chart createLiveChart( )
ChartWithAxes cwaBar = ChartWithAxesImpl.create( );
// Plot
cwaBar.getBlock( ).setBackground( ColorDefinitionImpl.WHITE( ) );
Plot p = cwaBar.getPlot( );
p.getClientArea( ).setBackground( ColorDefinitionImpl.create( 255,
255,
225 ) );
// Legend
Legend lg = cwaBar.getLegend( );
LineAttributes lia = lg.getOutline( );
lg.getText( ).getFont( ).setSize( 16 );
lia.setStyle( LineStyle.SOLID_LITERAL );
lg.getInsets( ).setLeft( 10 );
lg.getInsets( ).setRight( 10 );
// Title
cwaBar.getTitle( )
.getLabel( )
.getCaption( )
.setValue( "Live Chart Demo" );//$NON-NLS-1$
// X-Axis
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes( )[0];
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.VALUE_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.MIN_LITERAL );
xAxisPrimary.getTitle( )
.getCaption( )
.setValue( "Category Text X-Axis" );//$NON-NLS-1$
xAxisPrimary.setTitlePosition( Position.BELOW_LITERAL );
xAxisPrimary.getLabel( ).getCaption( ).getFont( ).setRotation( 75 );
xAxisPrimary.setLabelPosition( Position.BELOW_LITERAL );
xAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.BELOW_LITERAL );
.getLineAttributes( )
.setStyle( LineStyle.DOTTED_LITERAL );
.setColor( ColorDefinitionImpl.create( 64, 64, 64 ) );
xAxisPrimary.getMajorGrid( ).getLineAttributes( ).setVisible( true );
// Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.getLabel( ).getCaption( ).setValue( "Price Axis"
);//$NON-NLS-1$
yAxisPrimary.getLabel( ).getCaption( ).getFont( ).setRotation( 37 );
yAxisPrimary.setLabelPosition( Position.LEFT_LITERAL );
yAxisPrimary.setTitlePosition( Position.LEFT_LITERAL );
yAxisPrimary.getTitle( ).getCaption( ).setValue( "Linear Value Y-Axis"
);//$NON-NLS-1$
yAxisPrimary.setType( AxisType.LINEAR_LITERAL );
yAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.LEFT_LITERAL );
.setColor( ColorDefinitionImpl.RED( ) );
yAxisPrimary.getMajorGrid( ).getLineAttributes( ).setVisible( true );
// X-Series
Series seCategory = SeriesImpl.create( );
SeriesDefinition sdX = SeriesDefinitionImpl.create( );
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
// Y-Series (1)
BarSeries bs1 = (BarSeries) BarSeriesImpl.create( );
bs1.setSeriesIdentifier( "Unit Price" );//$NON-NLS-1$
bs1.setRiserOutline( null );
bs1.setRiser( RiserType.RECTANGLE_LITERAL );
Trigger tr1 = TriggerImpl.create(TriggerCondition.ONMOUSEOVER_LITERAL,
TooltipValueImpl.create(10, null)));
Trigger tr2= TriggerImpl.create(TriggerCondition.ONCLICK_LITERAL,
ActionImpl.create(ActionType.URL_REDIRECT_LITERAL,
URLValueImpl.create("http://www.google.com target=_blank" ,null
bs1.getTriggers().add(tr1);
bs1.getTriggers().add(tr2);
// Y-Series (2)
LineSeries ls1 = (LineSeries) LineSeriesImpl.create( );
ls1.setSeriesIdentifier( "Quantity" );//$NON-NLS-1$
ls1.getLineAttributes( ).setColor( ColorDefinitionImpl.GREEN( ) );
for ( int i = 0; i < ls1.getMarkers( ).size( ); i++ )
( (Marker) ls1.getMarkers( ).get( i ) ).setType(
MarkerType.BOX_LITERAL );
ls1.setCurve( true );
SeriesDefinition sdY = SeriesDefinitionImpl.create( );
yAxisPrimary.getSeriesDefinitions( ).add( sdY );
sdY.getSeriesPalette( ).shift( -1 );
sdY.getSeries( ).add( bs1 );
sdY.getSeries( ).add( ls1 );
// Update data
updateDataSet( cwaBar );
return cwaBar;
static final void updateDataSet( ChartWithAxes cwaBar )
// Associate with Data Set
TextDataSet categoryValues = TextDataSetImpl.create( sa );
NumberDataSet seriesOneValues = NumberDataSetImpl.create( da1 );
NumberDataSet seriesTwoValues = NumberDataSetImpl.create( da2 );
// X-Axis
SeriesDefinition sdX = (SeriesDefinition)
.get( 0 );
( (Series) sdX.getSeries( ).get( 0 ) ).setDataSet( categoryValues );
// Y-Axis
SeriesDefinition sdY = (SeriesDefinition)
.get( 0 );
( (Series) sdY.getSeries( ).get( 0 ) ).setDataSet( seriesOneValues );
( (Series) sdY.getSeries( ).get( 1 ) ).setDataSet( seriesTwoValues );
// Live Date Set
private static final String[] sa = {
"One", "Two", "Three", "Four",
"Five" ,//$NON-NLS-1$//$NON-NLS-2$//$NON-NLS-3$//$NON-NLS-4$//$NON- NLS-5$
"Six", "Seven", "Eight", "Nine",
"Ten" };//$NON-NLS-1$//$NON-NLS-2$//$NON-NLS-3$//$NON-NLS-4$//$NON -NLS-5$
private static final double[] da1 = {
56.99,
352.95,
-201.95,
299.95,
-95.95,
25.45,
129.33,
-26.5,
43.5,
122
private static final double[] da2 = {
20, 35, 59, 105, 150, -37, -65, -99, -145, -185
private Image imgChart;
private GC gcImage;
private Bounds bo;
static final void scrollData( ChartWithAxes cwa )
// Scroll the bar (Y) series
double dTemp = da1[0];
for ( int i = 0; i < da1.length - 1; i++ )
da1[i] = da1[i + 1];
da1[da1.length - 1] = dTemp;
// Scroll the line (Y) series
dTemp = da2[0];
for ( int i = 0; i < da2.length - 1; i++ )
da2[i] = da2[i + 1];
da2[da2.length - 1] = dTemp;
// Scroll X series
String sTemp = sa[0];
for ( int i = 0; i < sa.length - 1; i++ )
sa[i] = sa[i + 1];
sa[sa.length - 1] = sTemp;
updateDataSet( cwa );
* (non-Javadoc)
* @see
* org.eclipse.swt.events.PaintListener#paintControl(org.eclips e.swt.events
* .PaintEvent)
public final void paintControl( PaintEvent e )
Rectangle d = this.getClientArea( );
if ( bFirstPaint )
//if resized
imgChart = new Image( this.getDisplay( ), d );
gcImage = new GC( imgChart );
idr.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, gcImage );
bo = BoundsImpl.create( 0, 0, d.width, d.height );
bo.scale( 72d / idr.getDisplayServer( ).getDpiResolution( ) );
Generator gr = Generator.instance( );
try
//PrintWriter out = new PrintWriter( new FileWriter(
"c:/test/update.txt", true ) );
//out.println( "gr build and render");
//out.close();
if( bFirstPaint){
gcs = gr.build( idr.getDisplayServer( ), cm, bo, null, null, null );
}else{
gr.refresh( gcs );
gr.render( idr, gcs );
GC gc = e.gc;
gc.drawImage( imgChart, d.x, d.y );
catch ( Exception ce )
ce.printStackTrace( );
bFirstPaint = false;
Display.getDefault( ).timerExec( 500, new Runnable( ) {
public void run( )
chartRefresh( );
* (non-Javadoc)
* @see
org.eclipse.swt.events.SelectionListener#widgetDefaultSelect ed(org.eclipse
* .swt.events.SelectionEvent)
private void chartRefresh( )
if ( !isDisposed( ) )
final Generator gr = Generator.instance( );
scrollData( (ChartWithAxes) cm );
// Refresh
try
//out.println( "gr refresh");
//out.close();
gr.refresh( gcs );
catch ( Exception ex )
ex.printStackTrace( );
redraw( );
public void controlMoved(ControlEvent arg0) {
bFirstPaint = true;
public void controlResized(ControlEvent arg0) {
bFirstPaint = true;
Jason
> components.clear();
> components
> significantly.
> Best Regards
> Enrico
>> Enrico,
>> Jason
>>> Hallo,
>>> performance was ok.
>>> Thanks in advance
>>> Enrico
Current Time: Wed Apr 17 19:28:02 GMT 2024
Powered by FUDForum. Page generated in 0.03482 seconds
