Re: Problem with syntax trying to pass parameter to Java Object [message #490966 is a reply to message #490746] |
Mon, 12 October 2009 15:39 |
Richard
try
choices = sizingQuery.getChoice(parseInt(params["IntegerParameter"].value));
or just create an Integer like
importPackage(Packages.java.lang)
myint = new Integer(params["IntegerParameter"].value);
Jason
Richard Catlin wrote:
> This code does not properly pass the IntegerParameter to the Java
> method, which is expecting an Integer. When I replace
> params["IntegerParameter"] with a number it works.
> count = 0;
> sizingQuery = new Packages.com.oracle.esg.sizing.edit.query.SizingQuery();
> choices = sizingQuery.getChoice(params["IntegerParameter"]);
> This is the same syntax as mentioned in this post:
> http://stackoverflow.com/questions/1473844/accessing-paramet ers-when-writing-a-scripted-birt-data-source-in-java
> Richard
FUDForum. Page generated in 0.03670 seconds
