Home » Modeling » Epsilon » ETL transformations involving enumerations
ETL transformations involving enumerations [message #488492] |
Mon, 28 September 2009 21:27 |
Originally posted by: c.k.holmes.lboro.ac.uk
Hello All,
How does one map enumerations in ETL?
E.G. I have a source model auto-generated from an XML schema of the form:
SIGNALType
secClass : SecClassType
<more attributes/>
SecClassType
RED = 0
GREEN = 1
I have a target model defined in Emfatic of the form:
class Signal {
attr SigSecClassType secClass = "GREEN";
<more attributes/>
enum SigSecClassType {
RED = 0;
GREEN = 1;
I want to define a transformation rule to map objects of type SIGNALType
to objects of type Signal such that:
Target!s.secClass := Source!s.secClass
How should the ETL be expressed?
rule SignalType2Signal
transform sig1 : Source!SIGNALType
to sig2 : Target!Signal {
'SignalType2Signal'.println();
sig2.name := sig1.name;
sig2.secClass := sig1.secClass;
<blah/>
Suppose for some bizarre reason I wanted to transform the enumeration
literal values such that Source!SigSecClassType#GREEN mapped to
Target!SigSecClassType#RED, and Source!SigSecClassType#RED mapped to
Target!SigSecClassType#GREEN; how would I express this in the ETL?
Best Wishes
Chris
Re: ETL transformations involving enumerations [message #488523 is a reply to message #488498] |
Tue, 29 September 2009 06:28 |
Hi Dimitris,
Thanks for the reply. Would it be possible to access the source/target
enumeration literals by index? e.g.
Source!SecClass
RED // I assume this would have the default value 0
AMBER // 1?
GREEN // 2?
Target!enum SigSecClassType {
RED = 0;
AMBER = 1;
GREEN = 2;
If the mapping is simply:
Source!SecClass#RED => Target!SigSecClassType#RED
Source!SecClass#AMBER => Target!SigSecClassType#AMBER
Source!SecClass#GREEN => Target!SigSecClassType#GREEN
Then it would be more concise if I were to be able to define:
operation Nay transformSigSecClassType() : Integer {
return self.<how do I access the index of the enumeration literal?>
sig2.secClass.<attrib?> := sig1.secClasstransformSigSecClassType();
<blah/>
If this is possible, what is the syntax?
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> Enumeration literals are not objects and therefore you cannot define a
> rule to transform between them. However you can use an operation like
> the following
> operation Any transformSigSecClassType() {
> if (self = Source!SigSecClassType#GREEN) {
> return Target!SigSecClassType#RED;
> else {
> return Target!SigSecClassType#GREEN;
> (Ideally instead of Any, as context you should be able to specify
> Source!SigSecClassType but enumerations are not valid contexts for EOL
> operations)
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hello All,
>> SIGNALType
>> <more attributes/>
>> SecClassType
>> RED = 0
>> GREEN = 1
>> class Signal {
>> <more attributes/>
>> RED = 0;
>> GREEN = 1;
>> SIGNALType to objects of type Signal such that:
>> <blah/>
>> Best Wishes
>> Chris
Re: ETL transformations involving enumerations [message #488545 is a reply to message #488523] |
Tue, 29 September 2009 08:29 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Chris,
This is not possible I'm afraid. Could you please add an enhancement
request in the bugzilla so that we can keep track of this?
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> Source!SecClass
> AMBER // 1?
> GREEN // 2?
> RED = 0;
> AMBER = 1;
> GREEN = 2;
> <blah/>
> Best Wishes
> Chris
>> Hi Chris,
>> the following
>> else {
>> operations)
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hello All,
>>> form:
>>> SIGNALType
>>> <more attributes/>
>>> SecClassType
>>> RED = 0
>>> GREEN = 1
>>> class Signal {
>>> <more attributes/>
>>> RED = 0;
>>> GREEN = 1;
>>> <blah/>
>>> Best Wishes
>>> Chris
Re: ETL transformations involving enumerations [message #488549 is a reply to message #488545] |
Tue, 29 September 2009 08:42 |
Hi Dimitris,
OK, will do.
BTW what's the return type of the operation:
else {
i.e. what's the type of Target!SigSecClassType#<anyValidEnumLit>?
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> Source!SecClass
>> AMBER // 1?
>> GREEN // 2?
>> RED = 0;
>> AMBER = 1;
>> GREEN = 2; }
>> <blah/>
>> Best Wishes
>> Chris
>>> Hi Chris,
>>> a rule to transform between them. However you can use an operation
>>> like the following
>>> else {
>>> EOL operations)
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hello All,
>>>> form:
>>>> SIGNALType
>>>> <more attributes/>
>>>> SecClassType
>>>> RED = 0
>>>> GREEN = 1
>>>> class Signal {
>>>> <more attributes/>
>>>> RED = 0;
>>>> GREEN = 1;
>>>> <blah/>
>>>> enumeration literal values such that Source!SigSecClassType#GREEN
>>>> mapped to Target!SigSecClassType#RED, and Source!SigSecClassType#RED
>>>> mapped to Target!SigSecClassType#GREEN; how would I express this in
>>>> the ETL?
>>>> Best Wishes
>>>> Chris
Re: ETL transformations involving enumerations [message #488568 is a reply to message #488549] |
Tue, 29 September 2009 09:31 |
Hi Chris,
The return type should be Any as well (again ideally it should be
Target!SigSecClassType but this is not supported in EOL)
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> OK, will do.
> else {
> Best Wishes
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi Dimitris,
>>> source/target enumeration literals by index? e.g.
>>> Source!SecClass
>>> AMBER // 1?
>>> GREEN // 2?
>>> RED = 0;
>>> AMBER = 1;
>>> GREEN = 2; }
>>> <blah/>
>>> Best Wishes
>>> Chris
>>>> Hi Chris,
>>>> like the following
>>>> else {
>>>> EOL operations)
>>>> Cheers,
>>>> Dimitris
>>>> Chris Holmes wrote:
>>>>> Hello All,
>>>>> form:
>>>>> SIGNALType
>>>>> <more attributes/>
>>>>> SecClassType
>>>>> RED = 0
>>>>> GREEN = 1
>>>>> class Signal {
>>>>> <more attributes/>
>>>>> RED = 0;
>>>>> GREEN = 1;
>>>>> <blah/>
>>>>> Source!SigSecClassType#RED mapped to Target!SigSecClassType#GREEN;
>>>>> Best Wishes
>>>>> Chris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: ETL transformations involving enumerations [message #581137 is a reply to message #488498] |
Hi Dimitris,
Source!SecClass
AMBER // 1?
GREEN // 2?
RED = 0;
AMBER = 1;
GREEN = 2;
<blah/>
Best Wishes
Chris
> Hi Chris,
> the following
> else {
> operations)
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hello All,
>> SIGNALType
>> <more attributes/>
>> SecClassType
>> RED = 0
>> GREEN = 1
>> class Signal {
>> <more attributes/>
>> RED = 0;
>> GREEN = 1;
>> <blah/>
>> Best Wishes
>> Chris
Re: ETL transformations involving enumerations [message #581154 is a reply to message #488523] |
Hi Chris,
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> Source!SecClass
> AMBER // 1?
> GREEN // 2?
> RED = 0;
> AMBER = 1;
> GREEN = 2;
> <blah/>
> Best Wishes
> Chris
>> Hi Chris,
>> the following
>> else {
>> operations)
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hello All,
>>> form:
>>> SIGNALType
>>> <more attributes/>
>>> SecClassType
>>> RED = 0
>>> GREEN = 1
>>> class Signal {
>>> <more attributes/>
>>> RED = 0;
>>> GREEN = 1;
>>> <blah/>
>>> Best Wishes
>>> Chris
Re: ETL transformations involving enumerations [message #581175 is a reply to message #488545] |
Hi Dimitris,
OK, will do.
else {
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> Source!SecClass
>> AMBER // 1?
>> GREEN // 2?
>> RED = 0;
>> AMBER = 1;
>> GREEN = 2; }
>> <blah/>
>> Best Wishes
>> Chris
>>> Hi Chris,
>>> like the following
>>> else {
>>> EOL operations)
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hello All,
>>>> form:
>>>> SIGNALType
>>>> <more attributes/>
>>>> SecClassType
>>>> RED = 0
>>>> GREEN = 1
>>>> class Signal {
>>>> <more attributes/>
>>>> RED = 0;
>>>> GREEN = 1;
>>>> <blah/>
>>>> the ETL?
>>>> Best Wishes
>>>> Chris
Re: ETL transformations involving enumerations [message #581190 is a reply to message #488549] |
Hi Chris,
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> OK, will do.
> else {
> Best Wishes
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi Dimitris,
>>> Source!SecClass
>>> AMBER // 1?
>>> GREEN // 2?
>>> RED = 0;
>>> AMBER = 1;
>>> GREEN = 2; }
>>> <blah/>
>>> Best Wishes
>>> Chris
>>>> Hi Chris,
>>>> like the following
>>>> else {
>>>> EOL operations)
>>>> Cheers,
>>>> Dimitris
>>>> Chris Holmes wrote:
>>>>> Hello All,
>>>>> form:
>>>>> SIGNALType
>>>>> <more attributes/>
>>>>> SecClassType
>>>>> RED = 0
>>>>> GREEN = 1
>>>>> class Signal {
>>>>> <more attributes/>
>>>>> RED = 0;
>>>>> GREEN = 1;
>>>>> <blah/>
>>>>> Best Wishes
>>>>> Chris
Current Time: Sat Apr 20 01:36:34 GMT 2024
Powered by FUDForum. Page generated in 0.04404 seconds
