Home » Eclipse Projects » DTP » changing 'type' of output columns in dataset
changing 'type' of output columns in dataset [message #410] Mon, 27 June 2005 17:11 Go to next message
Originally posted by: no.spam.com
When I view the output columns of an dataset, the 'type' doesn't change.
Is this normal? Should that be able to be manipulated, or is it read-only
and based on the input data source? Any info appreciated...
Re: changing 'type' of output columns in dataset [message #1275 is a reply to message #410] Sat, 27 August 2005 20:23 Go to previous message
Der Ping Chou is currently offline Der Ping ChouFriend
Member
Mark,
Not sure if you are referring to the Data/sample content in output view or
Data Extract/load feature. Could you send me a screen shot?
Der Ping
Re: changing 'type' of output columns in dataset [message #566435 is a reply to message #410] Sat, 27 August 2005 20:23 Go to previous message
Member
Mark,
Der Ping
Previous Topic:Quantum
Next Topic:dtp and wst rdb
Current Time: Tue Apr 16 09:24:00 GMT 2024
Powered by FUDForum. Page generated in 0.30408 seconds
