Simple Hyperlink question [message #488171] |
Fri, 25 September 2009 18:44 |
Originally posted by: rbbnjmn.yahoo.com
I have a cross tab with three numeric columns.
In one of the columns I need to be able to click on the
number and navigate to an ordinary URL. I've got the URL
in the data set, and also in the data cube.
I've tried selecting the column and setting the Hyperlink
property. There is however no 'binding' unless I have also
added the data cube's href binding value to the report, adding
a column I don't need/want. Even trying this, I can bind
to the href, but of course it's not the href that's associated
with the data record value displayed in the column.
Hope this makes sense.
How can I access another value from the same data set record
in the expression builder?
Thanks!
Roy
Re: Simple Hyperlink question [message #488191 is a reply to message #488171] |
Fri, 25 September 2009 19:54 |
Roy,
Can you put the hyperlink on the measure. Take a look at this example.
It has scripting, but you do not need that. Just look at the
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.0.v20090603 Build <2.5.0.v20090617-0630></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<list-property name="userProperties">
<structure>
<property name="name">salesbydate.dsOrders.x</property>
<property name="type">integer</property>
<property name="isVisible">false</property>
</structure>
<structure>
<property name="name">salesbydate.dsOrders.y</property>
</structure>
<structure>
<property
name="name">salesbydate.ProductGroup.NewTabularHierarchy.x </property>
</structure>
<structure>
<property
name="name">salesbydate.ProductGroup.NewTabularHierarchy.y </property>
</structure>
<structure>
<property name="name">salesbydate.dsOrders.width</property>
</structure>
<structure>
<property name="name">salesbydate.dsOrders.height</property>
</structure>
</list-property>
<property name="salesbydate.dsOrders.x">251</property>
<property name="salesbydate.dsOrders.y">47</property>
<property
name="salesbydate.ProductGroup.NewTabularHierarchy.x">39</property >
<property
name="salesbydate.ProductGroup.NewTabularHierarchy.y">69</property >
<property name="salesbydate.dsOrders.width">150</property>
<property name="salesbydate.dsOrders.height">200</property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="customers" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<property name="displayName">CUSTOMERNUMBER</property>
</structure>
<structure>
<property name="columnName">CUSTOMERNAME</property>
<property name="displayName">CUSTOMERNAME</property>
</structure>
<structure>
<property name="columnName">CONTACTLASTNAME</property>
<property name="displayName">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="columnName">CONTACTFIRSTNAME</property>
<property
name="displayName">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="columnName">PHONE</property>
<property name="displayName">PHONE</property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE1</property>
<property name="displayName">ADDRESSLINE1</property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE2</property>
<property name="displayName">ADDRESSLINE2</property>
</structure>
<structure>
<property name="columnName">CITY</property>
<property name="displayName">CITY</property>
</structure>
<structure>
<property name="columnName">STATE</property>
<property name="displayName">STATE</property>
</structure>
<structure>
<property name="columnName">POSTALCODE</property>
<property name="displayName">POSTALCODE</property>
</structure>
<structure>
<property name="columnName">COUNTRY</property>
<property name="displayName">COUNTRY</property>
</structure>
<structure>
<property
name="columnName">SALESREPEMPLOYEENUMBER</property>
<property
name="displayName">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="columnName">CREDITLIMIT</property>
<property name="displayName">CREDITLIMIT</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">PHONE</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">ADDRESSLINE1</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">ADDRESSLINE2</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">CITY</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">STATE</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">POSTALCODE</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">COUNTRY</property>
</structure>
<structure>
<property name="position">12</property>
<property
name="name">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">CREDITLIMIT</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="nativeName">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="nativeName">PHONE</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE1</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE2</property>
</structure>
<structure>
<property name="nativeName">CITY</property>
</structure>
<structure>
<property name="nativeName">STATE</property>
</structure>
<structure>
<property name="nativeName">POSTALCODE</property>
</structure>
<structure>
<property name="nativeName">COUNTRY</property>
</structure>
<structure>
<property name="name">SALESREPEMPLOYEENUMBER</property>
<property
name="nativeName">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="nativeName">CREDITLIMIT</property>
<property name="nativeDataType">8</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from customers]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:uiHints>
<design:displayName>CUSTOMERNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>CONTACTLASTNAME</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>CONTACTLASTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTLASTNAME</design:label>
<design:attributes>
<design:name>CONTACTFIRSTNAME</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>CONTACTFIRSTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTFIRSTNAME</design:label>
<design:attributes>
<design:name>PHONE</design:name>
<design:position>5</design:position>
<design:uiHints>
<design:displayName>PHONE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PHONE</design:label>
<design:attributes>
<design:name>ADDRESSLINE1</design:name>
<design:position>6</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE1</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE1</design:label>
<design:attributes>
<design:name>ADDRESSLINE2</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE2</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE2</design:label>
<design:attributes>
<design:name>CITY</design:name>
<design:position>8</design:position>
<design:uiHints>
<design:displayName>CITY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CITY</design:label>
<design:attributes>
<design:name>STATE</design:name>
<design:position>9</design:position>
<design:uiHints>
<design:displayName>STATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATE</design:label>
<design:attributes>
<design:name>POSTALCODE</design:name>
<design:position>10</design:position>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>POSTALCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>POSTALCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COUNTRY</design:name>
<design:position>11</design:position>
<design:uiHints>
<design:displayName>COUNTRY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COUNTRY</design:label>
<design:attributes>
<design:name>SALESREPEMPLOYEENUMBER</design:name>
<design:position>12</design:position>
<design:uiHints>
<design:displayName>SALESREPEMPLOYEENUMBER</design:displayName >
</design:uiHints>
<design:usageHints>
<design:label>SALESREPEMPLOYEENUMBER</design:label>
<design:attributes>
<design:name>CREDITLIMIT</design:name>
<design:position>13</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>CREDITLIMIT</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CREDITLIMIT</design:label>
<design:displaySize>22</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
name="dsOrders" id="9">
<structure>
<property name="columnName">ORDERNUMBER</property>
<property name="displayName">ORDERNUMBER</property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<property name="displayName">PRODUCTCODE</property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<property name="displayName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<property name="displayName">PRICEEACH</property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<property name="displayName">ORDERLINENUMBER</property>
</structure>
<structure>
<property name="columnName">ORDERNUMBER_6</property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<property name="displayName">ORDERDATE</property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<property name="displayName">REQUIREDDATE</property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<property name="displayName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<property name="displayName">STATUS</property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<property name="displayName">COMMENTS</property>
</structure>
<structure>
</structure>
</list-property>
<structure>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="name">PRICEEACH</property>
</structure>
<structure>
<property name="name">ORDERLINENUMBER</property>
</structure>
<structure>
<property name="name">ORDERNUMBER_6</property>
</structure>
<structure>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="name">STATUS</property>
</structure>
<structure>
<property name="name">COMMENTS</property>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">ORDERNUMBER</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
</structure>
</list-property>
from CLASSICMODELS.ORDERDETAILS, CLASSICMODELS.ORDERS
where CLASSICMODELS.ORDERS.ORDERNUMBER =
CLASSICMODELS.ORDERDETAILS.ORDERNUMBER
and
CLASSICMODELS.ORDERS.STATUS = 'Shipped']]></xml-property>
<model:DesignValues
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>STATUS</design:name>
<design:uiHints>
<design:displayName>STATUS</design:displayName>
Re: Simple Hyperlink question [message #488198 is a reply to message #488191] |
Fri, 25 September 2009 21:33 |
If I understand correctly, the example bit is:
<structure name="action">
<property name="linkType">hyperlink</property>
<expression
name="uri">"http://www.google.com/search?source=ig&hl=en&rlz=1G1GGLQ_ENUS293&q="+data["year"] </expression>
<property name="targetWindow">_blank</property>
</structure>
So what I would use for my case is:
<expression name="uri">data["href"]</expression>
</structure>
I get an error:
ReportDesign (id = 1):
+ There are errors evaluating script "data["href"]":
The outer query results does not exist. This might be caused by a
"_outer" reference in a query without parent query. (<inline>#1)
Both the value displayed and the text string that is the link are in the
same record. Can I get the link value for a cross tab value with a MAX
function ?
Thanks for helping,
Roy
Jason Weathersby wrote:
> Roy,
> It has scripting, but you do not need that. Just look at the hyperlink
> on the measure.
> Jason
> id="1">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property
> </structure>
> <structure>
> <property
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <property
> <property
> <data-sources>
> <oda-data-source
> id="6">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property
> <property
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property
> </structure>
> <structure>
> </structure>
> </list-property>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> and
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
Re: Simple Hyperlink question [message #488199 is a reply to message #488191] |
Fri, 25 September 2009 21:41 |
<expression
</structure>
</structure>
I get an error:
function ?
Thanks for helping,
Roy
> Roy,
> on the measure.
> Jason
> id="1">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property
> </structure>
> <structure>
> <property
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <property
> <property
> <data-sources>
> <oda-data-source
> id="6">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property
> <property
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property
> </structure>
> <structure>
> </structure>
> </list-property>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> and
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
Re: Simple Hyperlink question [message #488200 is a reply to message #488191] |
Fri, 25 September 2009 21:53 |
<expression
</structure>
</structure>
I get an error:
function ?
Thanks for helping,
Roy
> Roy,
> on the measure.
> Jason
snip....
> </body>
> </report>
> Roy Benjamin wrote:
>> Thanks!
>> Roy
Re: Simple Hyperlink question [message #488396 is a reply to message #488200] |
Mon, 28 September 2009 14:17 |
Roy,
If you check the binding on the crosstab do you have an entry for href?
Jason
Roy Benjamin wrote:
> <expression
> </structure>
> </structure>
> I get an error:
> function ?
> Thanks for helping,
> Roy
>> Roy,
>> example. It has scripting, but you do not need that. Just look at
>> Jason
>> <?xml version="1.0" encoding="UTF-8"?>
> snip....
>> </body>
>> </report>
>> Roy Benjamin wrote:
>>> Hi,
>>> Thanks!
>>> Roy
FUDForum. Page generated in 0.02653 seconds
