Home » Archived » BIRT » problem with crosstab pagination(crosstab - page break.)
problem with crosstab pagination [message #487758] Thu, 24 September 2009 11:08 Go to next message
Alessio is currently offline AlessioFriend
Hi ,
In our report app , we are falled down in a glitch (I think) of the pdf emitter of birt runtime 2.2.2 (report engine api).
I've searched in the forums , but haven't found enough to solve this or work it around.
I've attached a pdf example of a report generated by our code in our environment , and the relative report and xmlData files.
The issue is visible from page 21 to page 29 of the pdf in attachment.
Trying to describe it , it appears when the crosstab makes the aggregation row exactly at the end of the page. In the next pages , the first two columns that display the dimension rows , are drawed splitted when there shouldn't be splitted. The issue vanishes when on one of the column chopped down is drawed another label of a new dimension.
Is there a work around for it ? Am I doing something wrong in the report design ?
Many thanks ,
Greetings.
Alessio
[Updated on: Thu, 24 September 2009 13:24]
Report message to a moderator
Re: problem with crosstab pagination [message #487801 is a reply to message #487758] Thu, 24 September 2009 13:21 Go to previous messageGo to next message
I don't know If the attachment is uploaded , can't see the symbol in the post.... so I've uploaded it also on another site...
http://myfreefilehosting.com/f/bc49cbf1b9_0.6MB
Greetings.
Alessio.
[Updated on: Thu, 24 September 2009 13:27]
Re: problem with crosstab pagination [message #487822 is a reply to message #487758] Thu, 24 September 2009 14:01 Go to previous messageGo to next message
No Message Body
[Updated on: Thu, 24 September 2009 14:01]
Re: problem with crosstab pagination [message #488102 is a reply to message #487822] Fri, 25 September 2009 14:53 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Alessio,
Can you try it with BIRT 2.5?
Jason
Alessio Lai wrote:
> http://myfreefilehosting.com/f/a01b395925_0.6MB
Previous Topic:Using the BIRT Designer outline View
Next Topic:Simple Hyperlink question
Current Time: Tue Apr 16 13:18:11 GMT 2024
Powered by FUDForum. Page generated in 0.18015 seconds
