Re: report problem : crosstab loses rows [message #487238 is a reply to message #487075] |
Tue, 22 September 2009 14:52 |
Alessio,
Have you tried with BIRT 2.5?
Can you log a bug for this?
BTW keep in mind that if you put code in the initialize method there is
the potential that it will run many times if you are using the /frameset
mapping. A better option may be to put it in the beforeFactory.
Jason
Alessio Lai wrote:
> Hi ,
> My company uses birt integrated in a web app.
> We build a report dynamically , using report engine api.
> In a certain situation (I've attached an example)
> when the query returns a number of rows equals to 110 ,
> the report shows only an inferior number of rows.
> The sad thing is that the number of rows presented in the generated
> report (pdf or xls or html) is at a first glance completely random !! .
> I have to say that this situations exists only on a debian 5.0 server
> , with x64 architecture and a 64-bit jvm. In all other architectures
> (windows 32 bit) it doesn't appear.
> Do you ever happened a similar issue ?
> Is there a solution ?
> I link at this post the report design (generated and written via report
> engine api) and the xml data and also the log generated by birt at
> runtime.
> Oh , I forgotten , I've monitored the onRowFetch method and it's called
> twice during report generation.
> The first time he fetches all the rows. The second time it blocks to a
> certain random row , without giving relevant errors.
> the report link : http://myfreefilehosting.com/f/68a9a64332_0.09MB
> the generated log : http://myfreefilehosting.com/f/5a03e1c335_0.03MB
> Many thanks ,
> Greetings .
> Alessio
FUDForum. Page generated in 0.02782 seconds
