Re: All "ALL" for dynamic parameters [message #487231 is a reply to message #487066] |
Tue, 22 September 2009 14:18 |
Hank,
I just uploaded an example to BIRT-Exchange.
http://www.birt-exchange.org/devshare/designing-birt-reports /1024-all-option-on-dynamic-parameter/#description
It shows dynamic parameter but not cascade.
Jason
Hank Burkhalter wrote:
> I understand how to allow "ALL" for a static parameter. Is it possible
> to allow an "ALL" for dynamic parameters? For dynamic cascading parameter?
> Thanks.
> Hank Burkhalter
> Roll Tide
Re: All "ALL" for dynamic parameters [message #487235 is a reply to message #487231] |
Tue, 22 September 2009 14:37 |
Simpler approach is located here:
http://www.birt-exchange.org/devshare/designing-birt-reports /1025-all-option-on-dynamic-parameter-pt2/#description
Jason Weathersby wrote:
> Hank,
> Jason
>> possible to allow an "ALL" for dynamic parameters? For dynamic
>> Thanks.
>> Hank Burkhalter
>> Roll Tide
Re: All "ALL" for dynamic parameters [message #487600 is a reply to message #487589] |
Wed, 23 September 2009 16:56 |
Hank,
What level of the cascade do you want the all?
Can you give a hypothetical example?
Jason
> Thanks Jason, that was fast.
> I took the ideas you gave and tried to apply them to a dynamic cascade
> parameter group without success. Do you think it is possible?
> Thanks.
> Hank
Re: All "ALL" for dynamic parameters [message #487873 is a reply to message #487855] |
Thu, 24 September 2009 16:06 |
Hank,
This becomes a bit messy when using a cacade. If you use strings it can
be done though. Attached is an example that does the all on the first
level. It also does an all on the second level but only on when the
parameter box is first displayed. You can fix this by using the joint
dataset approach I detailed yesterday.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.0.v20090603 Build <2.5.0.v20090617-0630></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="layoutPreference">auto layout</property>
<property name="bidiLayoutOrientation">ltr</property>
<parameters>
<cascading-parameter-group name="NewCascadingParameterGroup"
id="46">
<property name="dataSet">1stlevelcascade</property>
<property name="dataSetMode">multiple</property>
<parameters>
<scalar-parameter name="orderrange" id="47">
<property name="valueType">dynamic</property>
<property name="isRequired">true</property>
<property name="dataSetName">1stlevelcascade</property>
<expression
name="valueExpr">row["maxlevel"]</expression>
<expression
name="sortByColumn">dataSetRow["maxlevel"]</expression>
<property name="sortDirection">desc</property>
<property name="dataType">string</property>
<simple-property-list name="defaultValue">
<value type="constant">ALL</value>
</simple-property-list>
<property name="controlType">list-box</property>
<property name="fixedOrder">false</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="orderselect" id="48">
<property name="dataSetName">2ndlevelcascade</property>
<expression
name="valueExpr">row["ordernumberstring"]</expression>
<property name="fixedOrder">true</property>
</structure>
</scalar-parameter>
</parameters>
</cascading-parameter-group>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
<script-data-source name="sds" id="8"/>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="9">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<property name="displayName">ORDERNUMBER</property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<property name="displayName">PRODUCTCODE</property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<property name="displayName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<property name="displayName">PRICEEACH</property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<property name="displayName">ORDERLINENUMBER</property>
</structure>
</list-property>
<list-property name="parameters">
<structure>
<property name="name">param_1</property>
<property name="paramName">orderselect</property>
<property name="nativeName"></property>
<property name="nativeDataType">4</property>
<property name="position">1</property>
<expression name="defaultValue"
type="javascript">10101</expression>
<property name="isOptional">true</property>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<method name="beforeOpen"><![CDATA[if(
params["orderselect"].value == "ALL"){
inputParams["param_1"] = parseInt(0);
this.queryText = "select * from orderdetails where ordernumber > ?";
]]></method>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails
where ordernumber = ?
]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
</design:attributes>
<design:inputAttributes>
<design:elementAttributes>
<design:optional>true</design:optional>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
</design:DataSetParameters>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
name="2ndlevelcascade" id="44">
<list-property name="computedColumns">
<structure>
<property name="name">ordernumberstring</property>
<expression
name="expression">row["ORDERNUMBER"].toString()</expression >
</structure>
</list-property>
<structure>
</structure>
</list-property>
<structure>
<property name="name">minval</property>
<expression name="defaultValue">10000</expression>
</structure>
<structure>
<property name="name">maxval</property>
<expression name="defaultValue">30000</expression>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
params["orderrange"].value == "ALL" ){
inputParams["minval"] = parseInt(0);
inputParams["maxval"] = parseInt(1000000);
}else{
inputParams["minval"] = parseInt(params["orderrange"]-200);
inputParams["maxval"] = parseInt(params["orderrange"]);
]]></method>
<structure>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select ordernumber
from orders
where ordernumber >? and
ordernumber < ?]]></xml-property>
<model:DesignValues
<design:attributes>
<design:attributes>
</oda-data-set>
<script-data-set name="1stlevelcascade" id="45">
<list-property name="resultSetHints">
<structure>
<property name="position">0</property>
<property name="name">maxlevel</property>
</structure>
</list-property>
<structure>
<property name="columnName">maxlevel</property>
</structure>
</list-property>
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">sds</property>
<method name="open"><![CDATA[i=0;]]></method>
<method name="fetch"><![CDATA[if( i > 4 )return false;
if( i==4 ){
row["maxlevel"] = "ALL";
}else{
row["maxlevel"] = (parseInt(i*100)*2 + parseInt(10000)).toString();
i++;
return true;]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="6">
</style>
<style name="table-header" id="49">
<property name="backgroundColor">#6078BF</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="table-footer" id="50">
</style>
<style name="table-detail" id="51">
<property name="backgroundColor">#E6ECFF</property>
<property name="fontSize">x-small</property>
<property name="color">#000080</property>
</style>
<style name="table-group-header-1" id="52">
<property name="backgroundColor">#809FFF</property>
</style>
<style name="table-group-footer-1" id="53">
</style>
<style name="special-header" id="54">
<property name="fontSize">medium</property>
</style>
<style name="crosstab-detail" id="55">
</style>
<style name="crosstab-header" id="56">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">0.25in</property>
<property name="leftMargin">0.25in</property>
<property name="bottomMargin">0.25in</property>
<property name="rightMargin">0.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="10">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<column id="43"/>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="20">
<label id="21">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="22">
<cell id="23">
<data id="24">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="25">
<data id="26">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="27">
<data id="28">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="29">
<data id="30">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="31">
<data id="32">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="33">
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
<cell id="38"/>
</row>
</footer>
</table>
</body>
</report>
> Hello Jason.
> We are looking to move to BIRT, and first off is to see how close birt
> can mimic our current servlet/jsp/javascript reports. Common on our
> parameter pages is a dynamic cascading parameter group that allows an
> 'ALL' for each parameter. Of course, using servlet/jsp/javascript gives
> us 101 ways to do this.
> So say on one of our pages we have a dynamic cascading parameter group
> of four parameters. All four default to ALL. Each allow the selection
> of 'ALL' or a specific value. When the selection of an upper level
> parameter is changed the lower level parameter's are then updated
> (possibly causing the user to lose previous lower level selections).
> The user may change her mind about her selections before submitting,
> selecting some value then changing back to ALL then back again to some
> value.
> Anyway, this is (one of ) what we are hoping to do with BIRT.
> Roll Tide.
> Hank.
FUDForum. Page generated in 0.03751 seconds
