Home » Language IDEs » PHP Development Tools (PDT) » PDT-Error on Debugging of a PHP script
Re: PDT-Error on Debugging of a PHP script [message #485721 is a reply to message #485688] |
Mon, 14 September 2009 16:07 |
Originally posted by: dkel50.hotremovemail.com
What version of PDT are you using ? can you list the plugin versons of
PDT that are in use on your system ?
Dave Kelsey
On 14/09/09 14:27, Daniela Waranie wrote:
> Hi all,
> i am doing my first steps on debugging with PDT (eclipse).
> When i hit the "Debug"-button and then "PHP 5.2.10 (CLI)" in the debug
> perspective i got an error for this script:
> <CODE>
> <?php
> echo 'test PHP';
> echo ' done';
> </CODE>
> Program execution stops at line 2 with a dialog "Multiple problems have
> occurred":
> Error 1:
> An error has occurred. See error log for more details.
> org.eclipse.php.internal.debug.core.xdebug.dbgp.model.DBGpTa rget cannot
> be cast to org.eclipse.php.internal.debug.core.model.IPHPDebugTarget
> Error 2:
> Error 3:
> So 3 times the same error. When i click on "Show Error Log" i get the
> "Workspace log" with this message:
> <MESSAGE>
> java.lang.ClassCastException:
> at
> org.eclipse.php.internal.debug.ui.views.DebugViewHelper.getD ebugTarget(DebugViewHelper.java:84)
> at
> org.eclipse.php.internal.debug.ui.views.DebugViewHelper.getS electionElement(DebugViewHelper.java:44)
> at
> org.eclipse.php.internal.debug.ui.views.DebugOutputView.sele ctionChanged(DebugOutputView.java:130)
> at
> org.eclipse.ui.internal.AbstractPartSelectionTracker$1.run(A bstractPartSelectionTracker.java:119)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at org.eclipse.core.runtime.Platform.run(Platform.java:888)
> at
> org.eclipse.ui.internal.AbstractPartSelectionTracker.fireSel ection(AbstractPartSelectionTracker.java:117)
> at
> org.eclipse.ui.internal.WindowPartSelectionTracker$1.selecti onChanged(WindowPartSelectionTracker.java:38)
> at
> at
> at
> org.eclipse.ui.internal.PagePartSelectionTracker$1.selection Changed(PagePartSelectionTracker.java:49)
> at org.eclipse.ui.part.PageBookView$5.run(PageBookView.java:256 )
> at
> org.eclipse.ui.part.PageBookView$SelectionManager.selectionC hanged(PageBookView.java:254)
> at
> org.eclipse.ui.part.PageBookView$SelectionProvider.selection Changed(PageBookView.java:320)
> at
> org.eclipse.ui.part.PageBookView.pageSelectionChanged(PageBo okView.java:897)
> at org.eclipse.ui.part.PageBookView.access$2(PageBookView.java: 892)
> at
> org.eclipse.ui.part.PageBookView$2.selectionChanged(PageBook View.java:164)
> at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:162)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
> at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:160)
> at
> org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:2132)
> at
> org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedViewer.java:1669)
> at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer .java:1124)
> at
> org.eclipse.debug.internal.ui.viewers.model.InternalTreeMode lViewer.setSelection(InternalTreeModelViewer.java:1674)
> at
> org.eclipse.debug.internal.ui.viewers.model.InternalTreeMode lViewer.setSelection(InternalTreeModelViewer.java:1689)
> at
> org.eclipse.debug.internal.ui.viewers.model.TreeModelContent Provider.handleSelect(TreeModelContentProvider.java:356)
> at
> org.eclipse.debug.internal.ui.viewers.model.ModelContentProv ider.updateNodes(ModelContentProvider.java:947)
> at
> org.eclipse.debug.internal.ui.viewers.model.ModelContentProv ider.updateNodes(ModelContentProvider.java:953)
> at
> at
> at
> at
> org.eclipse.debug.internal.ui.viewers.model.ModelContentProv ider$9.runInUIThread(ModelContentProvider.java:862)
> at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
> </MESSAGE>
> As far as i can see i got this error 3 times in this log view.
> How can is solve this problem?
> Best regards
> Daniela Waranie
> PS:
> Eclipse build id: 20090619-0625
> Eclipse IDE for PHP DEvelopers 1.2.20090618-0925
Re: PDT-Error on Debugging of a PHP script [message #485882 is a reply to message #485852] |
Tue, 15 September 2009 12:29 |
I quickly downloaded PDT 2.1 All in One just to check but there are no
problems with that release.
The error you describe could only happen if somehow you were using some
old plugin support for xdebug in PDT and thus there were multiple
plugins within your eclipse system. Unfortunately the list you gave me
listed the features and the not the individual plugins for PDT.
The problem is due to the debug Output views (Browser Output and Debug
Output) not recognising the xdebug code.
You could try restarting eclipse with the "-clean" option if you have
some old plugins still around.
The pdt plugins will either be in the plugins directory or in the
dropins/eclipse/plugins directory.
It sounds like your PDT installation is not completely valid.
Dave Kelsey
On 15/09/09 11:03, Daniela Waranie wrote:
> Hi Dave,
> here the list of all installed PDT plugins (attached you can find a
> version without e-mail line brakes):
> PHP Development Tools (PDT) SDK Feature
> 2.1.0.v20090611-0930-51-84QACBIHRiLOmQMX3XhJh39Od
> PHP Development Tools (PDT) Runtime Feature
> 2.1.0.v20090613-1236-7L79-F8NcJKhKDUv9Y7en
> Dynamic Languages Toolkit - Core Frameworks
> 1.0.0.v20090610-1638-7C--EAAoOQBPbbrBcPz0b
> Eclipse Platform 3.5.0.v20090611a-9gEeG1HFtQcmRThO4O3aR_fqSMvJR2sJ
> Eclipse Help System 1.1.0.v20090602-7e7eFAlFEx2XZoYqwI68e2F
> Eclipse RCP 3.5.0.v20090519-9SA0FwxFv6x089WEf-TWh11
> Equinox p2 Provisioning 1.1.0.v20090605-1440-7u6Fb3FbPbJP5MjJjZgifk
> Eclipse Faceted Project Framework 3.1.0.v200906080522-377-8s733L3F3J3DAB
> Eclipse Web Developer Tools
> 3.1.0.v200905242131-7R77FShEVw2xUGpF1LiNxdVAELXy
> WST Common UI 3.1.0.v200903021835-7B5FREDhdMNPm7dkmBmpUJxRlMta
> WST Common Core 3.1.0.v200903021835-7B77FXTF7RZHITIwQkLs_V
> WST Server UI 3.1.0.v200901260254-7B3DLAtJZNyxfIUbDVOO4256
> WST Server Core 3.1.0.v200901260254-30Et8s733L3E4H
> WST Server User Documentation 3.1.0.v200903071919-209L7w311A12343145
> WST Web Core 3.1.0.v200901280206-7H77FD4AT7oFldDfJV4g-6iAAR_z
> WST Web Services Core
> 3.1.0.v200905132336-7L7RFTUFGtGcn6glz-kxdBF462A
> WSDL 1.5 Feature 1.5.3.v200903071919-2407w311917141519
> WST XML Core 3.1.0.v200901260254-7C7OFPeF7RZHIXHnTz0Jqc0
> WST Web Services UI 3.1.0.v200903020650-7I6FPlEtEnGxSBtv6tT6hoOXcS3b
> WST Web Services User Documentation
> 3.1.0.v200903071919-44FGz9oB55U5L8OAFEK
> WST Web User Documentation 3.1.0.v200903071919-31DF8s733J3E4D56BB
> Eclipse XML Editors and Tools
> 3.1.0.v200905240756-7H6FMVDxtkM-5OgPGKK4xQocS5AL
> WST XML User Documentation 3.1.1.v200906020459-50FR7AkF77f7MESDKEF
> Eclipse XSL Developer Tools 1.0.0.v200905242203-7R7T7IFIhIehWfz064pz0YX1
> JavaScript Developer Tools 1.1.1.v200906091427-77-FGBCcNBC-BeMcEeOm
> Usage Data Collector 1.1.0.R200906100410
> As you can see it is the standard PDT-eclipse bundle.
> Any thoughts about my problem?
> Best regards
> Daniela Waranie
Re: PDT-Error on Debugging of a PHP script [message #486098 is a reply to message #485882] |
Wed, 16 September 2009 10:53 |
Daniela Waranie Messages: 52 Registered: July 2009 |
Member |
--------------090806070404030508050703
Content-Type: text/plain; charset=UTF-8
Hi Dave,
attached you can find the list of plugins.
Since i run eclipse with the -clean option i do have trouble with the
"PHP Editor". So to keep on on this issue i installed aptana studio in
addion (as a eclipse plugin) and open the php file in theirs php editor
view.
Now, when i hit the "debug"-button / "PHP 5.2.10 (CLI)" the dialog:
"Problem occured"
appears.
Message:
'Debug Source Display' das encountered a problem.
An internal error has occurred.
org/eclipse/php/internal/ui/containers/StorageEditorInput
Details1:
A conflict occurred for CTRL+F2:
Binding(CTRL+F2,
ParameterizedCommand(Command(com.aptana.ide.editor.php.openH elp,Open
PHP Manual,
Category(com.aptana.ide.editors,All Aptana Editors,null,true),
LegacyHandlerWrapper(ActionHandler(action=com.aptana.ide.edi tor.php.PHPActionContributor$1@12e99be)),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
com.aptana.ide.editors.UnifiedEditorsScope,,,system)
Binding(CTRL+F2,
ParameterizedCommand(Command(org.eclipse.debug.ui.commands.T erminate,Terminate,
Terminate,
Category(org.eclipse.debug.ui.category.run,Run/Debug,Run/Deb ug command
category,true),
ActionDelegateHandlerProxy(null,org.eclipse.debug.internal.u i.commands.actions.TerminateCommandActionDelegate),
,,true),null),
org.eclipse.debug.ui.debugging,,,system)
Details2:
Keybinding conflicts occurred. They may interfere with normal
accelerator operation.
Details3:
Error logged from Debug Core:
java.io.IOException: Kein Prozess ist am anderen Ende der Pipe
at java.io.FileInputStream.readBytes(Native Method)
at java.io.FileInputStream.read(Unknown Source)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at java.io.FilterInputStream.read(Unknown Source)
org.eclipse.debug.internal.core.OutputStreamMonitor.read(Out putStreamMonitor.java:144)
org.eclipse.debug.internal.core.OutputStreamMonitor.access$1 (OutputStreamMonitor.java:134)
org.eclipse.debug.internal.core.OutputStreamMonitor$1.run(Ou tputStreamMonitor.java:207)
at java.lang.Thread.run(Unknown Source)
Details4:
Unhandled event loop exception
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NoClassDefFoundError: org/eclipse/php/internal/ui/PHPUiPlugin)
at org.eclipse.swt.SWT.error(SWT.java:3884)
at org.eclipse.swt.SWT.error(SWT.java:3799)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:137)
Caused by: java.lang.NoClassDefFoundError:
org.eclipse.php.internal.debug.core.launching.PHPLaunchUtili ties.shouldSwitchToPHPPerspective(PHPLaunchUtilities.java:21 2)
org.eclipse.php.internal.debug.core.launching.PHPLaunchUtili ties.access$0(PHPLaunchUtilities.java:210)
org.eclipse.php.internal.debug.core.launching.PHPLaunchUtili ties$4.run(PHPLaunchUtilities.java:198)
... 22 more
Caused by:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
An error occurred while automatically activating bundle
org.eclipse.php.ui (330).
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:376)
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:452)
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:321)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.core.internal.filebuffers.ExtensionsRegistry.get Extension(ExtensionsRegistry.java:227)
org.eclipse.core.internal.filebuffers.ExtensionsRegistry.doG etAnnotationModelFactory(ExtensionsRegistry.java:394)
org.eclipse.core.internal.filebuffers.ExtensionsRegistry.get AnnotationModelFactory(ExtensionsRegistry.java:408)
org.eclipse.core.internal.filebuffers.ResourceExtensionRegis try.getAnnotationModelFactory(ResourceExtensionRegistry.java :80)
org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer Manager.createAnnotationModel(ResourceTextFileBufferManager. java:123)
org.eclipse.core.internal.filebuffers.ResourceTextFileBuffer .getAnnotationModel(ResourceTextFileBuffer.java:160)
org.eclipse.ui.editors.text.TextFileDocumentProvider.createF ileInfo(TextFileDocumentProvider.java:594)
com.aptana.ide.editors.unified.BaseDocumentProvider.createFi leInfo(BaseDocumentProvider.java:194)
com.aptana.ide.editor.html.HTMLDocumentProvider.createFileIn fo(HTMLDocumentProvider.java:138)
org.eclipse.ui.editors.text.TextFileDocumentProvider.connect (TextFileDocumentProvider.java:478)
com.aptana.ide.editor.html.HTMLDocumentProvider.connect(HTML DocumentProvider.java:242)
org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:4134)
org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:203)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1413)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor .java:166)
com.aptana.ide.editors.unified.UnifiedEditor.doSetInput(Unif iedEditor.java:1955)
org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3115)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:759)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2578)
org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3133)
org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3160)
com.aptana.ide.editors.unified.UnifiedEditor.init(UnifiedEdi tor.java:338)
com.aptana.ide.editor.html.HTMLSourceEditor.init(HTMLSourceE ditor.java:231)
com.aptana.ide.editor.php.PHPSourceEditor.init(PHPSourceEdit or.java:1085)
org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:238)
org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:212)
com.aptana.ide.editor.html.MultiPageHTMLEditor.createPage0(M ultiPageHTMLEditor.java:347)
com.aptana.ide.editor.html.MultiPageHTMLEditor.createPages(M ultiPageHTMLEditor.java:828)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:357)
com.aptana.ide.editor.html.HTMLEditor.createPartControl(HTML Editor.java:405)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:662)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:271)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1417)
org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:942)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
... 18 more
Caused by: org.osgi.framework.BundleException: The activator
org.eclipse.php.internal.ui.PHPUiPlugin for bundle org.eclipse.php.ui is
invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:157)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:750)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
... 86 more
org/eclipse/php/internal/ui/preferences/PHPTemplateStore
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:152)
... 91 more
Caused by: java.lang.ClassNotFoundException:
org.eclipse.php.internal.ui.preferences.PHPTemplateStore
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:443)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 97 more
How can i solve my problem?
Thanks in advance.
Best regards
Daniela Waranie
name="plugins.txt"
Content-Disposition: inline;
filename="plugins.txt"
UEhQIERldmVsb3BtZW50IFRvb2xzIChQRFQpIFNESyBGZWF0dXJlCTIuMS4w LnYyMDA5MDYx
MS0wOTMwLTUxLTg0UUFDQklIUmlMT21RTVgzWGhKaDM5T2QNCiAgUEhQIERl dmVsb3BtZW50
IFRvb2xzIChQRFQpIFJ1bnRpbWUgRmVhdHVyZQkyLjEuMC52MjAwOTA2MTMt MTIzNi03TDc5
LUY4TmNKS2hLRFV2OVk3ZW4NCiAgICBEeW5hbWljIExhbmd1YWdlcyBUb29s a2l0IC0gQ29y
ZSBGcmFtZXdvcmtzCTEuMC4wLnYyMDA5MDYxMC0xNjM4LTdDLS1FQUFvT1FC UGJickJjUHow
Yg0KICAgICAgRWNsaXBzZSBQbGF0Zm9ybQkzLjUuMC52MjAwOTA2MTFhLTln RWVHMUhGdFFj
bVJUaE80TzNhUl9mcVNNdkpSMnNKDQogICAgICAgIEVjbGlwc2UgSGVscCBT eXN0ZW0JMS4x
LjAudjIwMDkwNjAyLTdlN2VGQWxGRXgyWFpvWXF3STY4ZTJGDQogICAgICAg IEVjbGlwc2Ug
UkNQCTMuNS4wLnYyMDA5MDUxOS05U0EwRnd4RnY2eDA4OVdFZi1UV2gxMQ0K ICAgICAgICBF
cXVpbm94IHAyIFByb3Zpc2lvbmluZwkxLjEuMC52MjAwOTA2MDUtMTQ0MC03 dTZGYjNGYlBi
SlA1TWpKalpnaWZrDQogICAgRWNsaXBzZSBGYWNldGVkIFByb2plY3QgRnJh bWV3b3JrCTMu
MS4wLnYyMDA5MDYwODA1MjItMzc3LThzNzMzTDNGM0ozREFCDQogICAgRWNs aXBzZSBXZWIg
RGV2ZWxvcGVyIFRvb2xzCTMuMS4wLnYyMDA5MDUyNDIxMzEtN1I3N0ZTaEVW dzJ4VUdwRjFM
aU54ZFZBRUxYeQ0KICAgICAgV1NUIENvbW1vbiBVSQkzLjEuMC52MjAwOTAz MDIxODM1LTdC
NUZSRURoZE1OUG03ZGttQm1wVUp4UmxNdGENCiAgICAgICAgV1NUIENvbW1v biBDb3JlCTMu
MS4wLnYyMDA5MDMwMjE4MzUtN0I3N0ZYVEY3UlpISVRJd1FrTHNfVg0KICAg ICAgV1NUIFNl
cnZlciBVSQkzLjEuMC52MjAwOTAxMjYwMjU0LTdCM0RMQXRKWk55eGZJVWJE Vk9PNDI1Ng0K
ICAgICAgICBXU1QgU2VydmVyIENvcmUJMy4xLjAudjIwMDkwMTI2MDI1NC0z MEV0OHM3MzNM
M0U0SA0KICAgICAgICBXU1QgU2VydmVyIFVzZXIgRG9jdW1lbnRhdGlvbgkz LjEuMC52MjAw
OTAzMDcxOTE5LTIwOUw3dzMxMUExMjM0MzE0NQ0KICAgICAgV1NUIFdlYiBD b3JlCTMuMS4w
LnYyMDA5MDEyODAyMDYtN0g3N0ZENEFUN29GbGREZkpWNGctNmlBQVJfeg0K ICAgICAgICBX
U1QgQ29tbW9uIENvcmUJMy4xLjAudjIwMDkwMzAyMTgzNS03Qjc3RlhURjdS WkhJVEl3UWtM
c19WDQogICAgICAgIFdTVCBTZXJ2ZXIgQ29yZQkzLjEuMC52MjAwOTAxMjYw MjU0LTMwRXQ4
czczM0wzRTRIDQogICAgICAgIFdTVCBXZWIgU2VydmljZXMgQ29yZQkzLjEu MC52MjAwOTA1
MTMyMzM2LTdMN1JGVFVGR3RHY242Z2x6LWt4ZEJGNDYyQQ0KICAgICAgICAg IFdTREwgMS41
IEZlYXR1cmUJMS41LjMudjIwMDkwMzA3MTkxOS0yNDA3dzMxMTkxNzE0MTUx OQ0KICAgICAg
ICBXU1QgWE1MIENvcmUJMy4xLjAudjIwMDkwMTI2MDI1NC03QzdPRlBlRjdS WkhJWEhuVHow
SnFjMA0KICAgICAgV1NUIFdlYiBTZXJ2aWNlcyBVSQkzLjEuMC52MjAwOTAz MDIwNjUwLTdJ
NkZQbEV0RW5HeFNCdHY2dFQ2aG9PWGNTM2INCiAgICAgICAgV1NUIFdlYiBT ZXJ2aWNlcyBD
b3JlCTMuMS4wLnYyMDA5MDUxMzIzMzYtN0w3UkZUVUZHdEdjbjZnbHota3hk QkY0NjJBDQog
ICAgICAgICAgV1NETCAxLjUgRmVhdHVyZQkxLjUuMy52MjAwOTAzMDcxOTE5 LTI0MDd3MzEx
OTE3MTQxNTE5DQogICAgICAgIFdTVCBXZWIgU2VydmljZXMgVXNlciBEb2N1 bWVudGF0aW9u
CTMuMS4wLnYyMDA5MDMwNzE5MTktNDRGR3o5b0I1NVU1TDhPQUZFSw0KICAg ICAgV1NUIFdl
YiBVc2VyIERvY3VtZW50YXRpb24JMy4xLjAudjIwMDkwMzA3MTkxOS0zMURG OHM3MzNKM0U0
RDU2QkINCiAgICBFY2xpcHNlIFhNTCBFZGl0b3JzIGFuZCBUb29scwkzLjEu MC52MjAwOTA1
MjQwNzU2LTdINkZNVkR4dGtNLTVPZ1BHS0s0eFFvY1M1QUwNCiAgICAgIFdT VCBDb21tb24g
VUkJMy4xLjAudjIwMDkwMzAyMTgzNS03QjVGUkVEaGRNTlBtN2RrbUJtcFVK eFJsTXRhDQog
ICAgICAgIFdTVCBDb21tb24gQ29yZQkzLjEuMC52MjAwOTAzMDIxODM1LTdC NzdGWFRGN1Ja
SElUSXdRa0xzX1YNCiAgICAgIFdTVCBYTUwgQ29yZQkzLjEuMC52MjAwOTAx MjYwMjU0LTdD
N09GUGVGN1JaSElYSG5UejBKcWMwDQogICAgICBXU1QgWE1MIFVzZXIgRG9j dW1lbnRhdGlv
bgkzLjEuMS52MjAwOTA2MDIwNDU5LTUwRlI3QWtGNzdmN01FU0RLRUYNCiAg ICBFY2xpcHNl
IFhTTCBEZXZlbG9wZXIgVG9vbHMJMS4wLjAudjIwMDkwNTI0MjIwMy03UjdU N0lGSWhJZWhX
ZnowNjRwejBZWDENCiAgICAgIEphdmFTY3JpcHQgRGV2ZWxvcGVyIFRvb2xz CTEuMS4xLnYy
MDA5MDYwOTE0MjctNzctRkdCQ2NOQkMtQmVNY0VlT20NCiAgICBQSFAgRGV2 ZWxvcG1lbnQg
VG9vbHMgKFBEVCkgU0RLIEZlYXR1cmUJMi4xLjAudjIwMDkwNjEzLTEyMzYt N0w3OS1GOE5j
SktoS0RVdjlZN2VuDQogIFVzYWdlIERhdGEgQ29sbGVjdG9yCTEuMS4wLlIy MDA5MDYxMDA0
MTANCg==
--------------090806070404030508050703--
Re: PDT-Error on Debugging of a PHP script [message #486302 is a reply to message #486098] |
Thu, 17 September 2009 08:25 |
I think your eclipse installation is really in a mess and you probably
have to get rid of it and start from scratch. The -clean ensures eclipse
is using the latest versions of plugins in your eclipse installation but
it sounds like you have a mismatch of version plugins which is causing
all the problems.
I really recommend that you download the PDT all in one version and
start from there. You should not have to install any extra stuff and you
won't be able to put the aptana plugins into PDT either.
Once you have PDT installed you can add extra plugins from eclipse.org
from the install/update facility within PDT itself
Dave Kelsey
On 16/09/09 11:53, Daniela Waranie wrote:
> Hi Dave,
> view.
> "Problem occured"
> appears.
> Message:
> Details1:
> Binding(CTRL+F2,
> PHP Manual,
> ,,true),null),
> Binding(CTRL+F2,
> Terminate,
> category,true),
> ,,true),null),
> Details2:
> Details3:
> at
> at
> at
> Details4:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 22 more
> Caused by:
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 18 more
> invalid
> at
> at
> at
> at
> at
> at
> ... 86 more
> at
> ... 91 more
> at
> at
> at
> at
> ... 97 more
> Thanks in advance.
> Best regards
> Daniela Waranie
Current Time: Thu Apr 18 22:51:21 GMT 2024
Powered by FUDForum. Page generated in 0.02765 seconds
