Debugging Facebook Applications using Eclipse [message #485171] |
Thu, 10 September 2009 17:08 |
Drawn Messages: 3 Registered: September 2009 |
Junior Member |
NetBeans can debug a FBML Facebook App and Eclipse can't?!
Say it isn't so!
Below is a helpful article in setting up an means to 'debug' a Facebook Application:
FB Series: Locally debug your PHP Facebook App
- Published: July 10, 2009
http://www.uebersoftware.com/2009/07/fb-series-locally-debug -your-php-facebook-app/
The author has been able to successfully issue breakpoints and debug a Facebook application using NetBeans 6.7.1.
He couldn't get it to work with Eclipse! Booooooo!!!
Regrettably, I too have failed. Boooooo!!!
My project is huge and so, when opening it in NetBeans, NetBeans is still running its "Scanning Projects" process, and it will be running for hours!
Essentially, making that IDE worthless to me!
Nope, Eclipse is my IDE, and I want to debug my Facebook application (Note: It uses FBML and not iFrame)!
Someone, please step up and get this to work for us!
Cheers.
Re: Debugging Facebook Applications using Eclipse [message #485294 is a reply to message #485171] |
Fri, 11 September 2009 08:47 |
Originally posted by: dkel50.hotremovemail.com
Have you tried turning on Remote Session Initiation for the XDebug
debugger for PDT ? See
http://www.eclipse.org/pdt/documents/XDebugGuideForPDT2.0.pd f
for more information.
I suggest using firefox and the xdebug firefox plugin to manage the
XDebug cookie that needs to be set in order for xdebug on the server to
active and allow debugging.
You will need to have source code available to you within PDT as well of
course otherwise you will be told that no suitable source will be located.
If you are going to activate the cookie yourself you can do this by
appending to the URL
?XDEBUG_SESSION_START=ECLIPSE_DBGP
you don't need the KEY value. This was used to get around IE 6 caching
which stopped you seeing changes to your php script. May not be a
problem in later versions of IE.
Dave Kelsey
> Say it isn't so!
> Application:
> for hours!
> Cheers.
FUDForum. Page generated in 0.03007 seconds
