Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » OCL compilation
Re: OCL compilation [message #49196 is a reply to message #48987] |
Thu, 07 September 2006 19:29 |
Hi, Laurent,
You raise some good problems. You may want to add yourself to the cc list
of an existing bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=144210
regarding providing a public API for parsing OCL documents. Evidently, the
internal API that you are currently using also has problems.
Could you please raise bugs for:
- the problem in the grammar file of classifier context not replicating
invOrDefCS
- the exception complaining that the 'self' context cannot be redefined
I can't promise fixes in time for the 1.0.1 release, but we'll see.
Christian
Laurent Le Goff wrote:
> Hello,
> I would like to extends my meta-model with constraints AND new Operation.
> I've chosen OCL language.
> I have some trouble to compile OCL expressions.
> I want to edit an ocl file like this :
> package test
> context TestClass def:
> test1(t:String): String =
> 'coucou1'.concat(t)
> def:
> test2(t:String): String =
> 'coucou2'.concat(t)
> endpackage
> I've tried to compile these definition. the Parser send me an error :
> misplace construct. I've rewritten the OCL with only one definition :
> package test
> 'coucou'.concat(t)
> endpackage
> The parser compile this expression with success. And I can invoke test2
> operation later, GREAT!
> PROBLEM :
> I would like to define and compile some OCL constraints or operation (inv
> or def) from files. And call these operations or constraints from other
> files or String like this
> IOCLHelper helper = HelperUtil.createOCLHelper();
> EObject context = (EObject)resource.getContents().get(0);
> helper.setContext(TestPackage.eINSTANCE.getTestClass());
> OCLExpression exp;
> // where exp is the compilation of the OCL file with constraints and
> operation
> exp = ExpressionsFactory.eINSTANCE.createOCLExpression(expressionS tring);
> System.out.println(helper.evaluate(context, "self.test1('toto')"));
> System.out.println(helper.evaluate(context, "self.test2('toto')"));
> ** First I've look at the grammar in your OCL plugin (OCLLPGParser.g
> :lpg grammar) and I think that this grammar block me (extended bnf
> :notation):
> package -> 'package' pathName context+ 'endpackage'
> | context*
> context -> classifierContext
> | operationContext
> | propertyContext
> classifierContext -> context pathName invOrDef
> * I would need this :
> classifierContext -> context pathName invOrDef+
> ** Secondly I've tried to do this in another way, I've rewritten the code
> : package test
> 'coucou1'.concat(t)
> 'coucou2'.concat(t)
> endpackage
> The parser accept this code but there's an exception thrown that tell me
> that 'self' (context) can't be redefined.
> The only solution that I saw is to re-run the parser with each new 'def'
> or 'inv:'. I don't like this solution.
> Please, Does anybody know how can I find the good way to compile OCL
> Expressions?
> Sorry for the long mail.
> Thanks for any helps
> Regards
> Laurent
Re: OCL compilation [message #49234 is a reply to message #49196] |
Fri, 08 September 2006 07:53 |
Laurent LE GOFF Messages: 15 Registered: July 2009 |
Junior Member |
hello Christian,
thanks for your answer. I entered bugs in bugzilla:
* grammar restriction
https://bugs.eclipse.org/bugs/show_bug.cgi?id=156656
* 'self' cannot be redefine
https://bugs.eclipse.org/bugs/show_bug.cgi?id=156657
I hope that bugs will have to be resolved in the next version ;-)
Laurent
Le Thu, 07 Sep 2006 15:29:00 -0400, Christian W. Damus a écrit :
> Hi, Laurent,
> of an existing bug:
> invOrDefCS
> Christian
>> Hello,
>> package test
>> 'coucou1'.concat(t)
>> def:
>> 'coucou2'.concat(t)
>> endpackage
>> package test
>> 'coucou'.concat(t)
>> endpackage
>> PROBLEM :
>> OCLExpression exp;
>> operation
>> :notation):
>> | context*
>> | operationContext
>> | propertyContext
>> : package test
>> 'coucou1'.concat(t)
>> 'coucou2'.concat(t)
>> endpackage
>> Expressions?
>> Regards
>> Laurent
Re: OCL compilation [message #590462 is a reply to message #48987] |
Hi, Laurent,
of an existing bug:
invOrDefCS
Christian
> Hello,
> package test
> 'coucou1'.concat(t)
> def:
> 'coucou2'.concat(t)
> endpackage
> package test
> 'coucou'.concat(t)
> endpackage
> PROBLEM :
> OCLExpression exp;
> operation
> :notation):
> | context*
> | operationContext
> | propertyContext
> : package test
> 'coucou1'.concat(t)
> 'coucou2'.concat(t)
> endpackage
> Expressions?
> Regards
> Laurent
Re: OCL compilation [message #590507 is a reply to message #49196] |
Junior Member |
hello Christian,
Laurent
> Hi, Laurent,
> of an existing bug:
> invOrDefCS
> Christian
>> Hello,
>> package test
>> 'coucou1'.concat(t)
>> def:
>> 'coucou2'.concat(t)
>> endpackage
>> package test
>> 'coucou'.concat(t)
>> endpackage
>> PROBLEM :
>> OCLExpression exp;
>> operation
>> :notation):
>> | context*
>> | operationContext
>> | propertyContext
>> : package test
>> 'coucou1'.concat(t)
>> 'coucou2'.concat(t)
>> endpackage
>> Expressions?
>> Regards
>> Laurent
Current Time: Fri Apr 19 19:58:10 GMT 2024
Powered by FUDForum. Page generated in 0.03152 seconds
