Home » Modeling » EMF » [Teneo] teneo jar signing problem?
Re: [Teneo] teneo jar signing problem? [message #482836 is a reply to message #482679] |
Fri, 28 August 2009 09:50 |
David Wynter Messages: 4624 Registered: July 2009 |
Martin,
I have now uninstalled Teneo and reinstalled the previous version, 3
times, back to the 30th July 2009 1.1.1 version now. I consistently get
the class signing exception for each version. Which makes me think that
maybe it is my particular use of the Teneo plugin that is causing the
problem. I also note that in the plugins folder, despite upgrading it
leaves all the original teneo jars from the Galileo release in place,
surely this leaves the potential for one of these getting loaded instead
of the latest version? However removing these made no difference to the
error, it still occurred.
I have 4 plugins, all use Teneo into different databases and one bundle
as follows:
Application plugin -+->Component1--+
| |->Component2--|
| |->Component3--+
V |
Hibernate bundle<-+
All plugins reference the same Hibernate bundle. Only the main
Application plugin reexports the teneo hibernate plugin.
Fortunately returning to Ganymede allows me to work, hoping to get to
use 3.5 before 3.6 comes out ;)
David
Martin Taal wrote:
> Hi David,
> Can you enter a bugzilla for this one with the complete stack trace?
> The 1.1.1 release will be at the same time as Eclipse 3.5.1, therefore
> it is build against that release. But in reality it will also work fine
> with 3.5.0.
> gr. Martin
> David Wynter wrote:
>> I am using the latest teneo 1.1.1RC2 on Ubuntu 9.0.4 64 bit with
>> latest OpenJDK.
>> It loads the Update site from a local archive without error.
>> One thing I was curious about is that the dependencies state Eclipse
>> gtk 3.5.1RC1 but I am still on 3.5 release and the build release notes
>> do not mention what changed to make it dependent on 3.5.1RC1, which I
>> am thinking is unrelated to this issue:
>> 2009-08-2713:36:50.585 GMT+0000 1237 [main] ERROR org.mortbay.log -
>> Failed startup of context
>> org.mortbay.jetty.webapp.WebAppContext@1232784a{/secm,/home/david/workspace/GenSec2/./web}
>> java.lang.SecurityException: class
>> "org.eclipse.emf.teneo.hibernate.HbMapperException"'s signer
>> information does not match signer information of other classes in the
>> same package
>> at java.lang.ClassLoader.checkCerts(ClassLoader.java:776)
>> Which looks like a gclib issue?
>> thx.
>> David
Re: [Teneo] teneo jar signing problem? [message #482863 is a reply to message #482836] |
Fri, 28 August 2009 11:11 |
Martin,
Looks like I have been trapped again, by another issue in 1.0.4 30th
June 2009 that is solved in 1.1.1, which of course I cannot use due to
the issues below.
The issue I have mentioned in the post to this newsgroup on the 4th July
2009
2009-08-2810:48:12.739 GMT+0000 47717 [main] ERROR org.mortbay.log -
Error starting handlers
java.lang.AbstractMethodError
org.hibernate.impl.SessionFactoryImpl.registerEntityNameReso lvers(SessionFactoryImpl.java:440)
org.hibernate.impl.SessionFactoryImpl.registerEntityNameReso lvers(SessionFactoryImpl.java:435)
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:330)
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1341)
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:171)
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:83)
org.eclipse.emf.teneo.hibernate.HbBaseSessionDataStore.getSe ssionFactory(HbBaseSessionDataStore.java:57)
co.uk.roamware.secmsecurity.manager.HibernateUtil.init(Hiber nateUtil.java:98)
Thx.
David
David Wynter wrote:
> Martin,
> as follows:
> | |->Component2--|
> | |->Component3--+
> V |
> Hibernate bundle<-+
> David
> Martin Taal wrote:
>> Hi David,
>> fine with 3.5.0.
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> latest OpenJDK.
>>> notes do not mention what changed to make it dependent on 3.5.1RC1,
>>> which I am thinking is unrelated to this issue:
>>> same package
>>> thx.
>>> David
Re: [Teneo] teneo jar signing problem? [message #482865 is a reply to message #482863] |
Fri, 28 August 2009 11:22 |
Damn hibernate3.jar looks a lot like hibernate3.jar... It still had the
3.3 version I tried to use with the Galileo Teneo rather than the 3.2.6
version used with Ganymede version of Teneo.
David
David Wynter wrote:
> Martin,
> the issues below.
> 2009
> at
> at
> at
> at
> at
> at
> at
> at
> Thx.
> David
> David Wynter wrote:
>> Martin,
>> get the class signing exception for each version. Which makes me think
>> that maybe it is my particular use of the Teneo plugin that is causing
>> the problem. I also note that in the plugins folder, despite upgrading
>> it leaves all the original teneo jars from the Galileo release in
>> place, surely this leaves the potential for one of these getting
>> loaded instead of the latest version? However removing these made no
>> difference to the error, it still occurred.
>> bundle as follows:
>> | |->Component2--|
>> | |->Component3--+
>> V |
>> Hibernate bundle<-+
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> therefore it is build against that release. But in reality it will
>>> also work fine with 3.5.0.
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> latest OpenJDK.
>>>> the same package
>>>> thx.
>>>> David
Re: [Teneo] teneo jar signing problem? [message #483062 is a reply to message #482865] |
Sun, 30 August 2009 14:36 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi David,
The class signing error occurs in Jetty, right?
There is one special jar file in the org.eclipse.emf.teneo.hibernate plugin: org.eclipse.emf.teneo.hibernate.extra.jar.
This jar is not signed because otherwise there would be issues with cglib. Maybe that's related....
For the rest I am a bit puzzled why this happens..
gr. Martin
David Wynter wrote:
> David
> David Wynter wrote:
>> Martin,
>> the issues below.
>> July 2009
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thx.
>> David
>> David Wynter wrote:
>>> Martin,
>>> think that maybe it is my particular use of the Teneo plugin that is
>>> causing the problem. I also note that in the plugins folder, despite
>>> upgrading it leaves all the original teneo jars from the Galileo
>>> release in place, surely this leaves the potential for one of these
>>> getting loaded instead of the latest version? However removing these
>>> made no difference to the error, it still occurred.
>>> bundle as follows:
>>> | |->Component2--|
>>> | |->Component3--+
>>> V |
>>> Hibernate bundle<-+
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> latest OpenJDK.
>>>>> Eclipse gtk 3.5.1RC1 but I am still on 3.5 release and the build
>>>>> release notes do not mention what changed to make it dependent on
>>>>> 3.5.1RC1, which I am thinking is unrelated to this issue:
>>>>> - Failed startup of context
>>>>> the same package
>>>>> thx.
>>>>> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Current Time: Thu Mar 28 23:54:27 GMT 2024
Powered by FUDForum. Page generated in 0.01746 seconds
