Re: [QVTO] Help with syntax for assigning values to attributes defined as a certain datatype. [message #482389 is a reply to message #482363] |
Wed, 26 August 2009 12:28 |
Sergey Boyko Messages: 171 Registered: July 2009 |
Hi Toñi ,
That error comes from the fact that 'java.util.List' doesn't specify
type of its' elements type. As consequence string can't be casted to
generic oclstdlib::T type.
I'd suggest here either change AType.class attribute type to NMTOKEN
with [0..-1] multiplicity or provide black-box Java library to set value
for such attributes.
Sergey
Toñi Reina Quintero wrote:
> Hi again,
> as you may suppose for my previous posts, I'm working with the
> xhtml.ecore metamodel. That is, I'm trying to generate some xhmtl from
> my source metamodel.
> The problem comes when I try to assign a value for the class
> attribute of the li type. The xhtml code I'm trying to obtain is
> something similar to the following one:
> <LI>
> <A CLASS="active" TITLE="News" HREF="./1-news.html"> News</A>
> </LI>
> For that, I have written the following constructor:
> constructor xhtml::LiType::LiType(current: siteMap::Node,
> iter:siteMap::Node){
> a += object xhtml::AType {
> _class += 'active';
> href:='./'+iter.fullFileName();
> title:=guardTexts(iter.label, iter.name);
> text:= title;
> The error is in the line _class+='active'. class has been defined as a
> NMTOKENS datatype. And this datatype has been defined having as a base
> the java.util.List. I suppose the problem is the syntax, so my concrete
> question is how can I assign the active value to the attribute class in
> this case?
> Thanks in advance,
> Toñi
FUDForum. Page generated in 0.02336 seconds
