Home » Modeling » GMF (Graphical Modeling Framework) » Registering Ecore metamodel.
Registering Ecore metamodel. [message #481406] Thu, 20 August 2009 20:03 Go to next message
Mihir is currently offline MihirFriend
Member
I want to use elements from an ecore metamodel in the graphica editor.
So the question is how to import and register metamodels in the editor??
Many thanks,
Mihir
Re: Registering Ecore metamodel. [message #481451 is a reply to message #481406] Fri, 21 August 2009 06:14 Go to previous messageGo to next message
Mihir,
You can use Load Resource... in the graphical Ecore editor to make other
Ecore models available as "Additional Resources".
Mihir wrote:
> Hello,
> Many thanks,
> Mihir
Ed Merks
Re: Registering Ecore metamodel. [message #481652 is a reply to message #481451] Sat, 22 August 2009 11:14 Go to previous messageGo to next message
Member
Hello Ed,
Thanks for the reply. I want to load all the external resources before
the editor is loaded. Where in the diagram code can I make changes for
this and what are those changes??
Mihir
Ed Merks wrote:
> Mihir,
> Mihir wrote:
>> Hello,
>> Many thanks,
>> Mihir
Re: Registering Ecore metamodel. [message #481674 is a reply to message #481652] Sun, 23 August 2009 06:46 Go to previous messageGo to next message
Mihir,
Something like EcoreUtil.resolveAll could be applied to the resource set
to load all referenced resources. If they aren't referenced you'd need
to know what URIs to load using ResourceSet.getResource. I'm not where
where in the diagram code you'd do that. You might try setting a
breakpoint in ResourceSetImpl.getResource and look at the call stack to
see where/how the main resource is being loaded to try to answer this
question yourself.
Mihir wrote:
> Hello Ed,
> Cheers,
> Mihir
> Ed Merks wrote:
>> Mihir,
>> other Ecore models available as "Additional Resources".
>> Mihir wrote:
>>> Hello,
>>> editor. So the question is how to import and register metamodels in
>>> the editor??
>>> Many thanks,
>>> Mihir
Ed Merks
Re: Registering Ecore metamodel. [message #481682 is a reply to message #481674] Sun, 23 August 2009 11:40 Go to previous message
Member
Hi Ed,
Many thanks for your reply.
Mihir
Ed Merks wrote:
> Mihir,
> question yourself.
> Mihir wrote:
>> Hello Ed,
>> Cheers,
>> Mihir
>> Ed Merks wrote:
>>> Mihir,
>>> Mihir wrote:
>>>> Hello,
>>>> the editor??
>>>> Many thanks,
>>>> Mihir
Previous Topic:Prevent deletion of connection labels
Next Topic:Position of the elements
Current Time: Sat Jul 20 19:08:31 GMT 2024
Powered by FUDForum. Page generated in 0.03658 seconds
