Home » Language IDEs » Java Development Tools (JDT) » disable a plugin programmatically?
disable a plugin programmatically? [message #48139] Wed, 04 June 2003 01:04 Go to next message
Originally posted by: billy.hotmail.com
We are developing applications to deploy on the eclipse framework,
and functionalities are provided as plugins. Users get
different functionalities based on their roles after they
log in.
When a user does not have the privilege to run certain
functionalities, we would like to turn it off dynamically
after authenticating the user.
How can we do that?
thanks
x
Re: disable a plugin programmatically? [message #50882 is a reply to message #48139] Thu, 05 June 2003 00:56 Go to previous messageGo to next message
> log in.
> How can we do that?
> thanks
> x
AFAIK, it is not possible to do that at the moment (because the plug-ins are
not dynamic). Ther's an Eclipse project, Equinox, which is addressing this
matter (but it's in a very early stage).
Stelian Iancu
Linux registered user 287835
Be different. Think.
Re: disable a plugin programmatically? [message #51053 is a reply to message #48139] Thu, 05 June 2003 18:08 Go to previous message
Originally posted by: adam.kiezun.gmx.net.remove
after startup all plugins are already identified, so neither adding or removing
them will succeed
one nasty way of getting what you want would be to hack the startup code (but i
guess there might be _no way_ you would do that in an API-clean way)
anyways, eclipse.plaftorm is your newsgroup, this issue has not too much to do
with jdt
cheers
a.
eclipse.org
Previous Topic:wizard page size
Next Topic:Class breakpoints?
Current Time: Tue Jul 22 15:35:47 EDT 2025
Powered by FUDForum. Page generated in 0.03167 seconds
