Re: Export help contents [message #472360] |
Sat, 01 March 2008 12:20  |
Originally posted by: nospam_kowalskilee.gmail.com
Hello Marko,
Note: I'm adding eclipse.platform.ua newsgroup also to this thread, as
that newsgroup is focused on UA items (help system/cheat sheets/forms/etc).
What do you mean by "(recursively)" in printing a topic?
AFAIK, there's no "export" action in the help system to export or
otherwise generate an offline readable module.
I can see a potential work around for your situation:
I'm looking at Eclipse 3.4 M5, and if you select a topic, you can use
the Print icon that's above the table of contents to generate a single
HTML page that contains that topic and its subtopics. It's *not* the
Print icon that's above the topic itself (on the right hand side)--it's
a Print icon with a little black down arrow that's in the left hand
frame above the full table-of-contents tree.
When you press the black down arrow of that Print button, select "Print
selected topic and all subtopics" choice. This will build a single HTML
page that contains all of those topics and sends that page to your
system browser.
Once that page appears in your system browser, then I expect you can use
your browser's menu File->Save Web Page option and save it as an
offline file that you can send to your managers.
Would you give that a try and let us know what you think?
Sincerely,
Lee Anne
http://www.linkedin.com/in/leeannekowalski
Marko T. wrote:
> Hello guys
> I have written lots of documentation for some Eclipse plugins. Now some
> of my "managers" want to read this documentation (offline because they
> have no Eclipse and do not want to install it only because of the doc).
> Is there any way to export the documentation for a certain topic and its
> subtopics as one or many html web page where the links that are used are
> resolved so that easy navigation between several web pages is possible.
> I know that I can print a topic (recursively) but here the links inside
> the html files are always pointing to the webserver. The only links
> working are the ones defined through the toc files.
> Thanks in advance for any hint
> Greetings Marko T.
Re: Export help contents [message #609974 is a reply to message #472360] |
Mon, 03 March 2008 20:05  |
I take it that you are using the print topics and all subtopics feature.
Making the links relative where possible would seem to be a useful
enhancement (although this would only work for links which stayed within
the area being printed). Can you open a bug against this? If it is easy
to do I may be able to get it into 3.4.
Re: Export help contents [message #623796 is a reply to message #472365] |
Thu, 10 December 2009 12:46  |
So, nobody created a bug? I guess it is too late now to get it in 3.4 or
3.5 :)
I am running 3.5 and it doesn't produce relative links still. Shall I
open a bug?
Thanks!
FUDForum. Page generated in 0.03553 seconds
