Problem with profile for SD [message #469074] |
Tue, 20 January 2009 04:00 |
Rasha Messages: 61 Registered: July 2009 |
Member |
Im using Papyrus 1.11 to create a sequence diagram and define my own
profile for the lifeline. Then, I use ATL transformation to select some
lifeline according to its stereotype. But ATL couldnt see the stereotype
and raises an error get unsupported on OclAny. I successfully did the
same with the class and usecase diagrams. I think the problem is in
defining or applying the profile in the sequence diagram. Do you have any
hint to solve this problem?
Also when I applied some stereotypes from MARTE profile, ATL couldnt see
the stereotyped element and didnt raise any error. I have UML profile for
MARTE 1.0.3 as a plug-in. Do I need something else?
Any help is greatly appreciated,
Rasha
FUDForum. Page generated in 0.03041 seconds
