Re: Is there anybody who use Papyrus UML? [message #469041 is a reply to message #469039] |
Fri, 19 December 2008 15:55 |
Rafael Chaves Messages: 362 Registered: July 2009 |
Actually, I believe that for Java's final *fields*, it would correspond
to StructuralFeature.isReadOnly ("whether the feature's value may be
modified by a client").
RedefinableElement.isLeaf ("whether it is possible to further specialize
a RedefinableElement") seems to correspond to Java's final classes or
methods.
So I guess the question is whether Papyrus exposes isReadOnly for
structural features.
Rafael
Sébastien Gérard wrote:
> in UML2, I think that this concept is supported by the isLeal attribute of a
> RedefinableElement. So for a Class (which is RedefinableElement) in Papyrus,
> you just need to check the check box of the isLeaf properties as shown in
> attached picture.
> Regards... Sébastien.
> Dr. Sébastien Gérard
> Head of MDD for DRES research project
> CEA LIST/LISE
> Boîte courrier 65, GIF SUR YVETTE
> CEDEX, F-91191 France
> Phone/fax : +33 1 69 08 58 24 / 83 95
> Leader of the Eclipse Component Papyrus (The UML2 Graphical Modeler):
> www.papyrusuml.org
> http://www.eclipse.org/modeling/mdt/?project=papyrus
> Before printing, think about the environment
> "Rafael Chaves" <rafael@abstratt.com> a écrit dans le message de news:
> gied0c$bp4$1@build.eclipse.org...
>> The Papyrus UML has its own newsgroup, which I copied this message to.
>>> I don't know how to create a final instance domain in a class by using
>>> class
>>> diagram.
>>> I use class diagram to create a class. I know how to create a class like
>>> this:
>>> class Employee
>>> private String name;
>>> but I don't know how to create a class like this:
>>> class Employee
>>> private final String name;
>>> Thank you in advance.
>>> Xiaogang Li
Re: Is there anybody who use Papyrus UML? [message #575457 is a reply to message #469039] |
methods.
Rafael
> attached picture.
> CEA LIST/LISE
> www.papyrusuml.org
>>> class
>>> diagram.
>>> this:
>>> class Employee
>>> class Employee
>>> Xiaogang Li
FUDForum. Page generated in 0.02621 seconds
