Home » Eclipse Projects » Rich Client Platform (RCP) » Hiding Actions using an Environmental Variable
Hiding Actions using an Environmental Variable [message #465007] Wed, 21 March 2007 18:16 Go to next message
Chris Grant is currently offline Chris GrantFriend
Member
Hi:
I have an RCP app and I want to be able to turn on and off actions via an
ENV VAR set in windows. We have good reasons for doing, although you may
ask :-).
I have tried this with something like this using visibility and
systemProperty:
<action
class="com.x4m.coreui.wizardview.ShowWizardViewAction"
id="com.x4m.seismicui.processing.ProcMultiVolumeWizardID"
menubarPath="com.x4m.seismicui.seismicmenu/seismicGroup"
style="push"
label="Process multiple volumes..."
tooltip="Process multiple volumes"> <visibility>
<systemProperty
name="AAPG2007"
value="true"/>
</visibility> </action>
but it still shows up if I have not set the ENV VAR AAPG2007
Can someone please offer some advice?
Chris
Re: Hiding Actions using an Environmental Variable [message #465104 is a reply to message #465007] Thu, 22 March 2007 22:46 Go to previous message
No real name is currently offline No real nameFriend
Member
Chris,
We have good luck using enablements on actions, including using system
properties. Here's an example:
<action
class="com.xxx.actions.AddFeaturesAction"
id="com.xxx.ui.addFeatures"
label="Add Features...."
menubarPath="help/com.xxx.ui.updateMenu/separator3"
style="push">
<enablement>
<systemProperty
name="feature.xxx"
value="true"/>
</enablement>
</action>
RN
Chris wrote:
> Hi:
> an ENV VAR set in windows. We have good reasons for doing, although you
> may ask :-).
> systemProperty:
> <action
> style="push"
> <systemProperty
> name="AAPG2007"
> value="true"/>
> Chris
Previous Topic:Getting a handle to IStatusLineManager
Next Topic:Extra space in wizard
Current Time: Wed Sep 11 20:11:46 GMT 2024
Powered by FUDForum. Page generated in 0.03380 seconds
